motor swap
Old Dec 21, 2002 | 09:24 PM
sic2kSi's Avatar
Default motor swap
i need some help , im dropping a 93' Ls motor into a 91' crx Si. i need to know what axles to get to make the drop. please help .... thanks
Old Dec 21, 2002 | 09:38 PM
I Gotta Question's Avatar
Default Re: motor swap (juz1badLS)
Me thinks you can use the axles off the LS if you use the hubs as well.But you may be able to use the axles with your hubs. I'm not to sure.
Old Dec 21, 2002 | 11:23 PM
big pete's Avatar
Default Re: motor swap (89_CRX_HF)
90-93 integ axles and intermediate shaft.....dont need to change the knuckles...you only need to change it if you have a hf
Old Dec 24, 2002 | 01:14 PM
slo2kSi's Avatar
Default Re: motor swap (big pete)
hey, thanks for the info..... thats all i needed to know.......... have a gr8 christmas
Old Dec 24, 2002 | 02:30 PM
Ef Whore's Avatar
Default Re: motor swap (slo2kSi)
if u went w/ a 90-91 ls u wouldnt have to convert to obd1, which i assume u are doing?
Old Dec 24, 2002 | 03:32 PM
Flexmyrex's Avatar
Default Re: motor swap (Ef *****)
you'll need 90-91 ls distributor, ecu, injectors (obd0)-- unless your converting to obd1.
rexbooming
Aug 21, 2010 02:49 PM
peter_vang
Apr 28, 2008 02:28 PM
93LS
Apr 5, 2008 01:19 PM
boosted_ejcivic
Apr 11, 2007 08:01 AM
sic2kSi
Dec 17, 2002 08:39 PM
