MAP senser...can i throw it away?
Old Dec 21, 2002 | 04:35 PM
turbohf's Avatar
Default MAP senser...can i throw it away?
k, i have a GM 2 bar map senser and want to install it (i have a Zdyne SECU Gold). so im going to be unplugging the honda map, so i want to clean up a little and toss it...but there are a coule other little purge valves or some **** hooked up with all that with vaccum lines. the vaccum line arent hooked up and havent been...ever. so anyway they have a 4pin connector on them, can i toss those too??? thanks
Old Dec 21, 2002 | 06:41 PM
AbaZ's Avatar
Default Re: MAP senser...can i throw it away? (turbohf)
yes you can... I have done it on every crx I have owned, I am suprised you have no installed that gm map sensor yet.
Jeff
Old Dec 21, 2002 | 06:53 PM
Malgerus's Avatar
Default Re: MAP senser...can i throw it away? (AbaZ)
lol
stick with the honda ones.
[Modified by Mr. S, 3:54 AM 12/22/2002]
Old Dec 21, 2002 | 06:56 PM
AbaZ's Avatar
Default Re: MAP senser...can i throw it away? (Mr. S)
lol
Well, sometimes I feel like being a "big boy" and running a little bit more then what the stock Honda map can read (roughly 1.0bar) .. That is why most people switch to GM map sensors. I run a GM 3.0bar map in my car.
Jeff
Old Dec 21, 2002 | 07:02 PM
turbohf's Avatar
well my car has a little stumble around 3-4k and one of my friends suggested it could be the map senser ******* up. and i have a 2 bar sitting right here and i can easeily program the Zdyne to read it, im just being lazy. the ****** wires wont reach either. mine MAP is on te far side of the firewall by the wiper motor, need somemore vacumm line...
Old Dec 21, 2002 | 07:05 PM
AbaZ's Avatar
jesus christ, is it that hard to extend 3 wires and install a longer vacuum hose? come on dustin, if you want to work on cars for living, why dont you get off your lazy *** and do it?
Jeff
Old Dec 21, 2002 | 07:11 PM
turbohf's Avatar
its ****** cold out in that garage!...im accually going out there right now to do it...
B18C Turbo
Jul 26, 2006 11:05 PM
Qveon
Jun 28, 2005 10:23 PM
turbohf
Dec 21, 2002 08:55 PM
