damn indicator is always on
ok, again with your english.
first off, it's not your "indicator" it's your brake light lamp.
my first guess would be to check my brake lights. have you gotten out of the car and had someone push on the brake pedal and checked to see if you have a break light out? probably first thing you should do before posting on the board. that or a search.
what does my post count matter on how much i know about accords? i have 2 accords currently, had 3, one was totalled by some chick. Then my sis and brother both have accords that i maintenance. the brake light is becuase there is a brake light problem. maybe wirng, could be fuse, could be a filiment out. I just had it come on mine last week and i checked, low nad behold, right brake light bulb burnt out. replaed it with an 1157 then it stopped. might want to check it out.
wait a minute who gives you guys the right to bark at me like im stupid i already checked that if it was the bulb it was like that when i first bought the car and the taillights still work so? what else can it be
dude, it's something with teh brake lights. that is the ONLY THING it can be. that's all that sets off that indicator. so all the brake lights work properly? all the bulbs work fine, all the tail lights work fine, there are no problems, no corroaded contacts or anything like that.
Replace the bulbs. my accod has the same type of problem.
I replace it and it will alays work for awhile
brake fluid doesn't matter with that light. that light is the brake LIGHT warning, nothing to do with fluid or tore up brake pads or anything like that. it's sorely telling you there is something wrong with the electric part back there, being a bulb out or stuck on or something. generally its' a bulb out.
Andrea_Aunie
Oct 20, 2001 11:46 AM
