Still Not Finished But Here Are Some More Pics
Old Dec 21, 2002 | 03:37 PM
SMSP's Avatar
Default Still Not Finished But Here Are Some More Pics
As you can see, this is a non sequential 4-2-1 header like the DC and Mugen but with significantly larger stepped primaries and secondaries. If this works out the #1 tube will go behind the #2-#4 tubes. It was done this way right now for ease of build. In addition merge collectors will be used for any production header so the power increases can be expected to be higher than what we get out of these pieces.
"Pictures Deleted"
Will work with a non modded Prelude engine mount, P/S and A/C. I'm about 95% sure on the A/C unit but don't have one handy to verify.
"Pictures Deleted"
Side shot looking towards #1
"Pictures Deleted"
Ground clearance wrt the oil pan.
"Pictures Deleted"
#4 tube in relation to front engine mount, notice mount is moved to the upper position of the slots.
"Pictures Deleted"
This 3rd header will be tested against the 2nd 4-2-1. Then the 2nd 4-2-1 will be modified slightly and retested against the 3rd 4-2-1.
Modified by SMSP at 11:02 AM 8/3/2003
Old Dec 21, 2002 | 03:55 PM
sslude's Avatar
Default Re: Still Not Finished But Here Are Some More Pics (SMSP)
those ar esome nice pics. keep up the good work
Old Dec 21, 2002 | 03:57 PM
TimeRacer's Avatar
Good job thus far! Nice clearance you're making w/ the ground. Though in contrast the set Mugen set that I have it seems like your primaries dive down right after the flange. I thought the 4 cyl Honda motors like long primaries? I'm probably wrong though.
Old Dec 21, 2002 | 04:08 PM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Still Not Finished But Here Are Some More Pics (TimeRacer)
are they gonna cost the same as mugen or more?
Old Dec 21, 2002 | 04:12 PM
prelude1897's Avatar
Default Re: Still Not Finished But Here Are Some More Pics (VtecDialect)
Looks good so far.
Old Dec 21, 2002 | 07:12 PM
SMSP's Avatar
It's better to have the tubes go straight or in line with the ports a bit before turning down. Like I stated above tubes 2-4 stay close just for this one because it was easier to build. If this header shows promise rerouting the #2-4 tubes should only help it.
Old Dec 21, 2002 | 08:51 PM
HotWheelz's Avatar
can you actually dyno this one in comparison with the other one... because i`m looking for a header and have cash, but i need proof it works well... EK-H22a.... looking for header with most midrange and high up top, dont`mind loosing bottom to slight midrange torque... can you build a better header than the HotShot 4-1 and if so how much and how long waiting....
Amazing what pipe bender an a tig welder can do hahahaahahaahh
-H-
Old Dec 22, 2002 | 04:34 AM
SMSP's Avatar
Default Re: Still Not Finished But Here Are Some More Pics (HotWheelz-turboh22dx)
-H-
This header (#3) will be dyno'd against the header that is currently on Corey's car (#2). Then header #2 will be slightly modified and then retested against header #3.
If you search under SMSP on the Prelude board you will find some dynos of the current and first header built for the stock H22.
Old Dec 22, 2002 | 06:23 AM
Missingsohc's Avatar
Dude your amazing!!! that is just a work of art, If it doesn't make power make it into a lamp!!!!
Old Dec 24, 2002 | 05:24 PM
K-Bom05's Avatar
Great job so far!
Old Dec 24, 2002 | 09:57 PM
Downey's Avatar
i want one! Will this fit on a H22A EG civic?
#Leo#
Dec 26, 2008 06:33 PM
1994PreludeSi
Oct 29, 2007 05:49 PM
R@mon
Mar 31, 2003 09:34 AM
EVOCELICA
12
May 9, 2002 05:28 PM
dplatt
Oct 29, 2001 09:42 PM
