Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
mounting seat to floor
Old Dec 21, 2002 | 02:35 PM
Lo-Buck EF's Avatar
Default mounting seat to floor
for those who have ever met me, u know i need more leg room in just about any car i drive. i was thinking about picking up a race seat and mounting it directly to the floor. but i was wondering if it is ok, safty wise, to just mount the seat to the floor pan. maybe i am missing something in the ways that others have done it. any help will be much appretiated. TIA
-spenc
Old Dec 21, 2002 | 02:57 PM
.RJ's Avatar
.RJ
Default Re: mounting seat to floor (SOLOef)
i would try to use the existing bolt holes - the floorpan is rather thin, however the stock mounting locations are reinforced. A race shop fabricator should be able to make you a bracket.
Old Dec 21, 2002 | 03:05 PM
DB2-R81's Avatar
25 Year Member
Default Re: mounting seat to floor (.RJ)
It is neither safe nor wise to bolt directly to the floor pan, to thin. Build a frame and attach it to reinforced portions of the chassis; sills, tunnel.
Old Dec 21, 2002 | 03:18 PM
upstatecrx's Avatar
Default Re: mounting seat to floor (DB1-R81)
is it legal in ITA to mount a racing seat to you stock sliders? or does it have to mounted solid to a frame?
Old Dec 22, 2002 | 11:44 AM
Lo-Buck EF's Avatar
anyone have any pics of this??
-spenc
Old Dec 22, 2002 | 12:00 PM
civicrr's Avatar
I posted this in a similar thread recently.
For the front: Used 1/2" X 2" rectangular tubing to span from tranny tunnel to rail (sill). Used 16 ga metal welded to areas where tubing would terminate to beef up the area & spread the load. Floorpan attached to the tubing mid-span. For the rear: Used section of tubing welded to the rail. Gusset attached to top of rail & tubing to triangulate. Also tied into floorpan. This piece did not span the whole distance. Incorporated the 'stock' mount on the other side. Used material welded to the raised area. Tied it into the tran. tunnel & down to floorpan. The piece of 16 ga used @ the tran. tunnel for reinforcement was made large enough to help reinforce the seat belt anchor area as well. FIA approved Sparco (or you could use Momo - they look/fit the same) slider attached to the tubing. Modified Sparco side mount bracket to fit slider. Sorry, no pics.
Old Dec 22, 2002 | 12:46 PM
Crosser's Avatar
Spec,
Your best bet if you want to pick up a racing bucket is to find the one that fits you best. This is very important. Find a shop or place that carries a bunch of seats you can try. Once you have that. Take it to a reputible race fab shop that can help you mount it properly and provide you with the extra leg room you need. It may not require a custom mount be made, but a good shop can help you determine that.
EC
Old Dec 22, 2002 | 02:29 PM
DB2-R81's Avatar
25 Year Member
Default Re: mounting seat to floor (Crosser)
See the frame in the pasanger side.
Over built!
Pictures borrowed from IT and ?
[Modified by DB1-R81, 3:31 PM 12/22/2002]
Old Dec 22, 2002 | 02:33 PM
Lo-Buck EF's Avatar
cool. have to find a shop. there is one by me, but they did a horrible job on my friends alignment. so i would hate to see what they would to with a torch in my car. anyone on long island/tri-state area have any ideas/info on race shops??
-spenc
Old Dec 22, 2002 | 02:35 PM
Lo-Buck EF's Avatar
sweet pics btw
-spenc
Old Dec 23, 2002 | 11:32 AM
Lo-Buck EF's Avatar
i just realized my sponcer has a welder at his place, so i can use that. let the fun begin (yes, i know how to weld)
-spenc
DMF
Feb 8, 2006 05:17 PM
Simon Tibbett
Sep 5, 2003 07:21 PM
auto-x
Jan 25, 2003 11:54 AM
bulldog_RS20
Dec 17, 2002 07:41 PM
C-Murdock
Oct 31, 2002 04:33 PM
