HA! hatch doesnt start :(
Old Dec 21, 2002 | 02:08 PM
Urban Business
Guest
Posts: n/a
Default HA! hatch doesnt start :(
gets fuel
turns over
new batery
resanded grounds on batery cable and thurmostat body
wasnt getting spark
i swap coils it got spark w/ plugs out
put plugs back in... no spark
pulled plugs retested, no spark
resistance in both msd coils and a stock coil thats never been used are the exact same. so im leaning twards it not being a coil issue.
WTF!?
[Modified by TorteX, 5:11 PM 12/21/2002]
Old Dec 21, 2002 | 02:48 PM
xXx Justin xXx's Avatar
Default Re: HA! hatch doesnt start :( (TorteX)
check your dizzy cap and rotor. they might be burned up or old. rotor nasty or cap old and nasty= rotted away... cannot deliver spark. and i would suggest getting new plugs if they are burned up. maybe a lot of carbon build up. or getting nasty b/c you keep dumping fuel against them without spark...? just things went through when my 88 dx wouldn't start. turned out i had to change plugs, cap, rotor, and coil... and check your plug wires maybe?
Old Dec 21, 2002 | 02:51 PM
Hondasaurs's Avatar
Default Re: HA! hatch doesnt start :( (SOHC Beast)
I had the same problem. I replaced the ignitor. This may be your problem.
Old Dec 21, 2002 | 02:54 PM
Hcivic88's Avatar
Default Re: HA! hatch doesnt start :( (ZC_CRX)
take off your distributor cap, make sure that screw for the rotor is still on, I've heard of this happening to a lot of people.
also, like someone else already mentioned, if u have a friend close by with a 4th gen civic, swap plug wires with them to see if it'll make a difference.
Old Dec 21, 2002 | 03:00 PM
Hondasaurs's Avatar
Default Re: HA! hatch doesnt start :( (Hcivic88)
Yes this happened to me before my ignitor went. Make sure the screw is nice and tight.
Old Dec 21, 2002 | 05:07 PM
philly-O's Avatar
i had a similar problem and changed everything, cap, rotor plugs, wires , fuel filter,etc. but it ended up being the main relay. i only had starting problems whrn it was hot as hell outside. thats why i missed the wilde show
Old Dec 21, 2002 | 05:08 PM
Timmayeg's Avatar
New User
same thing happend to me last night, i think its my igniter though it was corroded to hell, damn 88-91's anyway.
Old Dec 21, 2002 | 05:28 PM
chillincivic's Avatar
Default Re: HA! hatch doesnt start :( (91_EF_Civic)
Same thing just happened to me today too. I replaced the igniter and went on my marry little way
Old Dec 21, 2002 | 05:35 PM
USDM 4G VTEC's Avatar
check for the main relay
check that all injectors are trowing fuel
make sure all ignition related stuff are in working conditions...
make sure fuel pump its working
main relay affect Fuel injection and ecu related power...
other than that i can really think what ur problem its ....
Old Dec 21, 2002 | 05:38 PM
spun Vtec's Avatar
Default Re: HA! hatch doesnt start :( (JDM EF9)
yeah my crx wouldnt srart when it was really hot and then if you let it sit for a wile it would start right up! you think its the main relay?
Old Dec 21, 2002 | 06:16 PM
johnzm's Avatar
Default Re: HA! hatch doesnt start :( (4gsicivichatch)
have someone crank it while u put a test light on the wire going from teh ignitor t the coil.
Old Dec 21, 2002 | 06:51 PM
philly-O's Avatar
swapping the main relay did fix that problemfor me. i guess it is common for the solder traces to crack inside the relay.
Old Dec 22, 2002 | 12:28 AM
Urban Business
Guest
Posts: n/a
Default Re: HA! hatch doesnt start :( (peichie)
fixed.
2 problems:
plugs were grounding out to themselves for some reason.
cillys loaded up w/ fuel
unplugged connector A fromt he ecu (kills power to ecu thus injectors etc). cranked motor to get all the fuel out of cillys.
finally started up. crapy idle as a result of a/f mixture. super weird since the set up ive been running has worked fine for 3 months.
my entire ignition systems is 3 months old so i knew it wasnt dizzy etc etc. combo of cillys loaded full of fuel and shitty NGK plugs did it.
[Modified by TorteX, 3:30 AM 12/22/2002]
EGLUVN
May 17, 2007 12:53 PM
fassassin
Feb 7, 2005 05:02 PM
BadBeck
Dec 11, 2003 05:59 PM
2k1_ITR_0736
17
Jan 26, 2003 04:09 PM
96whitels
Aug 19, 2001 02:06 AM
