hey b16 swappers, need you help
Old Dec 21, 2002 | 12:52 PM
stockcrx's Avatar
Default hey b16 swappers, need you help
i put in my b16 last night. happy to say it runs like a champ. problem is my lower exhaust manifold wont clear the front cross member? its a good 1-3 inches off. have anyone of you guys run into this problem and what did you do to fix it? i have the hasport billet aluminum mounts if that makes any difference.
p.s. did try searching. no success.
Old Dec 21, 2002 | 01:11 PM
MADEINIRAQ's Avatar
Default Re: hey b16 swappers, need you help (stockcrx)
never had that problem. sorry
Old Dec 21, 2002 | 01:22 PM
stockcrx's Avatar
Default Re: hey b16 swappers, need you help (madeiniraq)
wow. i wonder why it wont fit then? this is really troubling me...
Old Dec 21, 2002 | 01:28 PM
raene's Avatar
Yeah, mine is fine also...
Do you have pics?
Old Dec 21, 2002 | 01:34 PM
Jared's Avatar
stock manifold? what mount kit?
Old Dec 21, 2002 | 01:37 PM
stockcrx's Avatar
Default Re: hey b16 swappers, need you help (Jared)
i got my engine from hmo. it came with stock exhaust manifold. like i said its the hasport mount kit. argh i am soo angry!!. the front crossmember is important. i dont want to cut it!
Old Dec 21, 2002 | 10:18 PM
xXsarcasmXx's Avatar
never heard of the problem....you can get a smaller more outta the way crossmember though....I think they sell some at jdmhondaparts.com ...but as for your problem....hmm
Old Dec 21, 2002 | 10:54 PM
slowpokesi's Avatar
i had the same problem, however my 00 si b16a stock manifold fit just fine, see if you can pick one up
Old Dec 22, 2002 | 09:53 AM
omahaturbocivic's Avatar
Default Re: hey b16 swappers, need you help (slowpokesi)
I replied in you hyrbid forum post as well. I just did a b series swap into my friends 90 hatch and we had to notch the crossmember a little to make the header clear. Some aftermarket mounts sit the engine a bit more forward than others. Just take the crossmember out and bolt the manifold on, then just cut out what you must to get the crossmember back on. At first it looked it would take quite a bit out but once the header was on we realizded just the very top need to be cut down a bit. Just dont go overboard cutting and you will be okay.
Old Dec 22, 2002 | 09:56 AM
b16_madman's Avatar
Default Re: hey b16 swappers, need you help (omahaturbocivic)
i dont know if this helps, but we had to cut a small piece of my front crossmember mount so that it wouldnt hit on it, but i dunno...
Old Dec 22, 2002 | 10:01 AM
burkee83's Avatar
I had to cut mine to make it fit..that front lower mount...i did'nt even use it!
Old Dec 22, 2002 | 12:24 PM
C uR eX's Avatar
you have to do a little cutting on the cross-member for the clearence!
Old Dec 22, 2002 | 11:33 PM
stockcrx's Avatar
Default Re: hey b16 swappers, need you help (C uR eX)
hey. i can get a 2000 si exhaust manifold from a friend. is there any difference? will this help me with clearance problems? also will an additonal o2 senser be there or not? god im soo angry. my cars been done forever and i cant even drive it!
Old Dec 23, 2002 | 12:28 AM
crxgurlllll's Avatar
is it the mount bracket that isnt allowing it to clear? if so cut it off you dont need it anyways......
if its the stock manifold.....well it shouldnt be interfering
Old Dec 23, 2002 | 01:09 AM
RenoRacing's Avatar
Default Re: hey b16 swappers, need you help (eraser)
invest in some of this action!!!! you'll love it and you'll have about 10 inches of room then!!!
other than that, i've never heard of this problem. i bet the SI one is smaller because of all the A/c and P/S crap, try it out!!! good luck
Old Dec 23, 2002 | 05:15 AM
slowpokesi's Avatar
using the 00si manifold worked for me but it only has one o2 bung,
plus the pipes are a little bigger, not much but they are bigger.
Old Dec 23, 2002 | 06:02 AM
stockcrx's Avatar
aha. so my clearance issues will be solved with this manifold. now about this o2 situation. i now have 2? or 1? and the 00 si would ha ve how many? again thanks agian.
EP3_05's Avatar
I used the stock 1990 integra xsi manifold and downpipe that came with my swap. I am using Hasport mounts as well. Fit fine with no problems and bolted right up to my exhaust.
Old Dec 23, 2002 | 06:13 AM
rice_classic's Avatar
Default Re: hey b16 swappers, need you help (91civic)
You should use the mani that came with it. Did you get the slots that are meant for the original "front motor mount" out of the way... I had to do that, everyone b16 swap has to do that. Check out this picture of how I did it to my front x-member.
Old Dec 23, 2002 | 06:14 AM
Default Re: hey b16 swappers, need you help (rice_classic)
I had to use a saw and cut notches into them so I could take a LARGE sledge hammer and pound them against the x-member so they would be flush and out of the way... I only did the pounding because cutting them off completely would have been TOO much work.
Old Dec 23, 2002 | 06:49 AM
stockcrx's Avatar
yeah i had to bend those fuxxers outta the way to get the tranny to fit in well. but as for the exhaust manny, i still can get a 00si manifold. would this be a better fit? cuz the xsi one blows *** for fitment.
Old Dec 23, 2002 | 12:28 PM
RenoRacing's Avatar
or you could do this too!!! look clean and room for jdm headers or turbo, i had this before i made my solid radius rod/chromoly setup.
Old Dec 25, 2002 | 03:59 PM
stockcrx's Avatar
Default Re: hey b16 swappers, need you help (HavokRacing)
wow that looks good havok racing. but how do i do that? i am EXTREMELY POOR! i was just thinking about beating the crap outta it.
Old Dec 25, 2002 | 04:42 PM
RenoRacing's Avatar
i can send you another one that i made that's looks just like the one above! let me know if you're interested. shipping would probably be like 20$ so maybe 40$'s shipped? if not thats cool, just let me know.
Old Dec 26, 2002 | 05:51 PM
stockcrx's Avatar
wow i would love that. its just taht i am super poor. let me get back to you on that one in about 3 days.. i ll know then.
Agtronic
Welding / Fabrication
15
May 20, 2007 08:36 AM
Spence
Sep 19, 2005 07:48 PM
stockcrx
Dec 22, 2002 04:09 PM
johnzm
11
Jul 30, 2002 06:15 PM
REDBARON
42
Jul 5, 2002 08:23 PM
