D-series to B-series in your EG, throttle cable...
Old Dec 21, 2002 | 09:26 AM
fOmaNPu's Avatar
Default D-series to B-series in your EG, throttle cable...
Just got done with a swap and of course, the throttle cable doesn't reach.
How did you go about extending your throttle cable bracket or rigging whatever setup to work with your new motor? Posting pictures would be a huge help!!!
Thanks in advance.
Old Dec 21, 2002 | 09:42 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: D-series to B-series in your EG, throttle cable... (fOmaNPu)
I used my stock one... no rigging... doh!
Old Dec 21, 2002 | 09:43 AM
Lysawy's Avatar
Default Re: D-series to B-series in your EG, throttle cable... (SkyeC)
made custom bracket!
Old Dec 21, 2002 | 09:47 AM
fOmaNPu's Avatar
Default Re: D-series to B-series in your EG, throttle cable... (Lysawy)
You and I have the exact same setup, do you have a picture of the custom bracket you made?
Old Dec 21, 2002 | 11:47 AM
fOmaNPu's Avatar
Bump, no one that has done this swap has a picture of their engine bay?
Old Dec 21, 2002 | 01:33 PM
Cynical 1's Avatar
Here you go.
The stock throttle cable is simply removed from the stock bracket and run along the firewall, and to the throttle body.
If you look along the top of the firewall, you'll see it... Right above the fuel filter.
[Modified by Revolveu2, 4:34 PM 12/21/2002]
Old Dec 21, 2002 | 01:35 PM
mantic6t9's Avatar
Default Re: D-series to B-series in your EG, throttle cable... (Revolveu2)
So you CAN use the stock throttle cable?
Old Dec 21, 2002 | 01:40 PM
Cynical 1's Avatar
Default Re: D-series to B-series in your EG, throttle cable... (mantic6t9)
Most do.
Every car I've done has used the stock one.
The only difference I can see from the stock and the GSR/SiR cable is the mount is different. It's on the driver side shock tower for the D-series, and over by the passenger side on the others.
Cable lenghts are a little different, too.
But, you can use the stock one. If you don't like it being loose, just zip-tie it to the fuel filter bracket or something.
Old Dec 21, 2002 | 03:08 PM
One Bad GeeSeeR's Avatar
depends on what type b-series engine you have. when i had my gsr swap in my eg stock throttle cable worked. just like the picture above. now when i took the gsr out and put a b16 in the cable was short or better yet the mount for the throttle cable made it short. so i rigged the throttle bracket from my old cx motor and the bracket from the b16. to extend the length. i'll try to get pics of my rigged bracket.
Carlo
Old Dec 21, 2002 | 03:47 PM
POLLO's Avatar
Default Re: D-series to B-series in your EG, throttle cable... (ChampwhiteSi)
Most people manage to rig their stock SOHC throttle cable. I use ITR /b16a throttle cable.
hth
Old Dec 21, 2002 | 05:31 PM
owen_the_soyboy's Avatar
me too
94 GSR swap into my 92 CX hatch, I used the CX cable
element1791
Dec 23, 2014 05:35 PM
boostingisfun
Aug 27, 2007 04:54 PM
whiteblurr
Jan 19, 2004 07:06 PM
CunninLynguist
25
Oct 26, 2003 10:14 AM
Ruby Civic
Mar 27, 2003 04:02 AM
