my dsm injectors do not fit!!!!!!
Old Dec 21, 2002 | 08:33 AM
move_right's Avatar
Default my dsm injectors do not fit!!!!!!
I have a 98 GSR integra. I am doing a turbo project, so I bought some DSM 450cc injectors off of dsmtrader.com and also the ECG map controller. these injectors do not fit. exactly what year and model car do the injectors need to come off of to fit? please be specific.
thanks.
Old Dec 21, 2002 | 08:44 AM
LEON's Avatar
Default Re: my dsm injectors do not fit!!!!!! (vinny)
You need to get different clips for them to fit. RC Engineering sells them for ~$35.
Old Dec 21, 2002 | 09:03 AM
MikePalm's Avatar
Default Re: my dsm injectors do not fit!!!!!! (LEON)
You can use the clips off of many cars with that type injector. You also need to bore out the seal in your intake manifold a bit becasue the injectors are a bit fatter than the honda ones. Don't forget the resistor box too.
Old Dec 21, 2002 | 11:08 AM
The Mole's Avatar
Default Re: my dsm injectors do not fit!!!!!! (MikePalm)
i have a set already packaged ready to be shipped
chris
Old Dec 21, 2002 | 11:29 AM
justinCO's Avatar
Yea make sure to do that or obviously they will not come close to fitting. They are not just pop-in and go injectors...
Justin
Old Dec 21, 2002 | 11:53 AM
cock head's Avatar
Default Re: my dsm injectors do not fit!!!!!! (Blake)
modify the injectors not the clip
Old Dec 21, 2002 | 01:10 PM
civicwagonman's Avatar
Default Re: my dsm injectors do not fit!!!!!! (therumblingteg)
I simply modified my injector clips, now they'll fit either injectors. ground out the tab in the corner if I remember correctly.
Old Dec 21, 2002 | 01:47 PM
move_right's Avatar
Default Re: my dsm injectors do not fit!!!!!! (civicwagonman)
DAMN! I have to bore out the holes in the intake manifold!!??? what do I use to do that? isn't that a precision hole? how would I bore it bigger with no leaks?
Old Dec 21, 2002 | 01:53 PM
project dc2's Avatar
you bore out the grommet .. godammit SEARCH FOR DSM 450 !! and you'll see why
Old Dec 21, 2002 | 02:21 PM
shortyz's Avatar
Default Re: my dsm injectors do not fit!!!!!! (project dc2)
h
[Modified by shortyz, 3:23 PM 12/21/2002]
[Modified by shortyz, 3:24 PM 12/21/2002]
Old Dec 21, 2002 | 03:57 PM
why are u callin project dc2 a dumb ***?
he is callin the other dude a dumbass .. he just clicked ont he reply window in my slot .
Old Dec 21, 2002 | 05:29 PM
move_right's Avatar
wow shorty z. you are so awesome. you really make me feel bad. too bad I have respect for this board so I don't tell you what I think.. REALLY too bad you don't live near me so I could show you. awesome dude. way to flame someone on a public board. you're my hero.
if you have an IQ that starts with a decimal, you shouldn't be posting and wasting server space. thanks.
Old Dec 21, 2002 | 05:32 PM
move_right's Avatar
how are you supposed to dremel a rubber seal? how is that precise? wouldn't the rubber seal just melt from friction?
Old Dec 21, 2002 | 06:11 PM
TheShocker's Avatar
Nope they dont melt. Just give it a try using a dremel and you'll see. If you make sure you dont dremel too much and make sure the injectors fit in nice and snug you should definatly not have any leakage problems.
Oh, and this has been covered many times over in the past. Next time try and use the search function before you post. Just some friendly advice, since you're new here.
Old Dec 21, 2002 | 08:17 PM
AbaZ's Avatar
Its actually very simple to grind the grommets out. using a dremel or die grinder, with some type of bit (carbide whatever) and just work the inside of the grommet cutting the rubber away evenly, take maybe 2mm away. Just make sure the grommet slides over the injector (semi-snug). Use some lube when putting them in the intake manifold, make it a bit easier too.
For the wiring, you can use a Injector resistor box, or even easier, go to radio shack and get some 10watt 10ohm resistors and wire them inline on each power wire for the injectors. Its pretty simple.
As someone stated, modify the injector, not the factory connector, just get a razor blade and cut out the center alignment on the injector, peice of cake.. I am doing a write up on this pretty soon, already got the pics..
Jeff
Old Dec 21, 2002 | 09:08 PM
CalvitoSol's Avatar
Default Re: my dsm injectors do not fit!!!!!! (AbaZ)
i'm not sure, i have some dsm's on my b16a and i didn't have to drill anything out. i just jammed in there as much as possible and bolted down the fuel rail. there are threads somewhere in the archives that cover this. i know that it doesn't go in all the way and you end up w/ a gap where the injector and the intake mani meet but everyone says its fine. you can also buy some grommets that fills in that space but i don't think that's really necessary.
Old Dec 21, 2002 | 09:15 PM
senpai's Avatar
Default Re: my dsm injectors do not fit!!!!!! (theory48)
You can use a faucet washer as the lower injector seal. Worked fine for me.
Old Dec 22, 2002 | 02:03 AM
MiraiZ's Avatar
Default Re: my dsm injectors do not fit!!!!!! (maztur)
10,001st time that this problem has been posted....SEARCH!! damn n00bs!
Old Dec 22, 2002 | 04:55 AM
b18CT's Avatar
Default Re: my dsm injectors do not fit!!!!!! (MiraiZ)
be easy there whit noob there!we all learn from somewhere
Old Dec 22, 2002 | 07:45 AM
GraphiteAccord's Avatar
Default Re: my dsm injectors do not fit!!!!!! (REVTurbo)
some people need to bore out the gromet, some can just jam it in there.
092eg6
Dec 23, 2009 01:38 PM
blkb18
May 18, 2008 05:42 PM
integrx
Dec 4, 2003 12:57 AM
paulzy
Sep 3, 2001 12:18 PM
