Back tire wobble...?? help please
It could just be the tire too, go get the tire changed and if it doesn't clear up its prolly the rim.
My back tire and front drivers side tires wre doing that, turns out the tires were just bad. Didn't realize that until the tire blew up and whacked away at my fenders, and jacked it all up...friggin sheet metal
thanks for the info guys..thats what i thought. well..its still under warranty so back to the dealer i go....this is the second time they have "fixed" this problem
everyone seems to have missed the obvious here, i bet your wheel weight just fell off. that will definately make it wobble. you can get it fixed for about $1.
I worked in a tire shop for a year and a half and the most common ailment was wobbling tires. Solution? Get your wheels and tires balanced. I doubt it's a bent rim because that usually makes your car pull to one side...if it's not pulling you probably just shed a weight. Then again, you could have bent a strut, bent a lug stud, badly warped a rotor (you would have many other problems if it were that), etc. Get it balanced at SAM's for like 8 bucks and if the problem persists, get back to us.
have u looked at the TRAILING ARM BUSHING??
i bet its ripped/broken. happens a lot of on older EF's, shouldnt be happening on a ek so soon tho but who knows.
erikiksaz1
Sep 2, 2006 01:52 PM
erikiksaz1
Apr 5, 2004 10:15 PM
