Need Help QUICK!!!!!!
Hey guys, I am trying to do the front brakes on my 90 STD, and I can't get the rotors off! The little screws will not come lose at all. My question is:
HOW DO YOU GET THESE THINGS TO COME OFF???
You need an impact screw driver.
Go to the local auto parts store and buy an impact screw driver. then use a heavy sledge hammer to pound the screws loose.
Try the above post first. If that fails to work, or you strip the heads, it's medieval time...
5/8" bit, and a drill.
grab the remainding studs with locking pliers, and pray they'll move. If you do the drilling quick enough, the heat won't make the screws stick to the hub.
It's your choice on putting new screws back in or not... they're just a convenience for assembly.
amej8
24
Apr 27, 2007 05:15 PM
