starter problems
blah !!! eversince we dropped in the D16Z6 in my friends 89 civic hatch we've had problems .. first off it wont start and the altenator isnt charging, so we changed to a proper workin altenator and a new starter and get this .. damn thing still wont start !@$&*@#(^@*( after 4K RPM it bogs ( DIY Turbo .. cam gear, 3 inch exhaust etcc) the fan turns on etcc .. no blown fuses .. what could be wrong >?>?
maybe explain the situation a bit better?
Does the car crank?
do you have 12v at the starter?
is the starter solnoid wire hooked up?
main fuse and relay are ok?
If the car does crank, do you have fuel? how about spark?
Jeff
Does the car crank?
Jeff
Does the car crank?
Jeff
Does the car crank?
Jeff
the wire with the spade connector ././?? thats in ... we at first had an old starter and it didnt start .. and replace dit with a new one .. same symptoms
its a new starter ... the car does not crank .. it can be push started tho ... not sure about the main fuse and relay [/QUOTE]
Thas a battery issue.......or ignition problem....hows the coil on the d16z....??
Yuta
Jun 28, 2014 12:52 PM
