75 shot nitrous=75 flywheel hp?
Old Dec 20, 2002 | 10:07 PM
4ghatch's Avatar
Default 75 shot nitrous=75 flywheel hp?
just want to find out how much hp i getting from the bottle never really found out. Let me know how to figure it out please
Old Dec 20, 2002 | 10:39 PM
rOby's Avatar
Default Re: 75 shot nitrous=75 flywheel hp? (4ghatch)
no way to tell., too many variables especially fuel pressure.
best way is to dyno it
Old Dec 21, 2002 | 05:37 AM
CRVRX's Avatar
Default Re: 75 shot nitrous=75 flywheel hp? (roby)
Depend on the kit , most of them are figure at crank HP , which should be 55 ish to the wheels with a manual transmsion.
Old Dec 21, 2002 | 07:04 AM
pelotudo's Avatar
What type of setup are you running? Is it a wet or dry system, and do you have any fuel upgrades done?
If you're running a Zex or any other dry kit, no; you're not getting 75hp out of it. With the dry kits, you're getting about 35-55 actual HP, and that might be stretching the #'s a little bit.
With a wet kit, you are either getting this or damn near it; as long as you have proper fuel and jets. It really depends on your setup though, and whether you have it set up correctly.
The only real way to determine what you're actually getting from the bottle is to dyno it...
jB
Old Dec 21, 2002 | 08:37 AM
sslude's Avatar
Default Re: 75 shot nitrous=75 flywheel hp? (PeloTudo)
if you have an atuo, you'll get less hp ratings because of the time it takes for the power to get through the tranny and to the ground.
Old Dec 21, 2002 | 08:56 AM
Slick GS-R's Avatar
Default Re: 75 shot nitrous=75 flywheel hp? (sslude)
check out my webpage in my sig.........i gained 61 wheel horsepower off of my zex kit (75 shot)..........
butter99
Dec 10, 2006 02:08 PM
97grnrs
Jan 2, 2006 02:07 PM
n20teg
Jul 30, 2003 06:12 PM
speedy108
May 5, 2002 05:10 PM
