I have a GSR rear sway bar- what else do I need to install on a 95 Coupe?
As topic states, I got a GSR rear sway bar for x-mas from a friend of mine
, but could anyone tell me what I need beyond the swaybar itself to put it on my coupe?
He got it from Import Auto Salvage, and it came with the bar itself and what looks like the end links and bushings. Aside from the mounting hardware (bolts, etc) is there anything else I need?
Also, if anyone was inclined to show me a pic of one on their 5th gen, I would appriceate it. TIA.
, but could anyone tell me what I need beyond the swaybar itself to put it on my coupe? He got it from Import Auto Salvage, and it came with the bar itself and what looks like the end links and bushings. Aside from the mounting hardware (bolts, etc) is there anything else I need?
integra lower control arms.
sway bar
endlinks
hardware
and the brackets that hold the bar itself to the subframe.
sway bar
endlinks
hardware
you could use LCA's from 94+ integras, civic ex sedan, and ef civic si's....i got mine from a 91 civic si, and it's the same exact thing, but i ran into a problem bolting the bar onto the subframe, the wholes were a little too big so i had to purchase longer bolts from home depot and washers..everything worked out great...pm me if you have any problems
OK, thanks for your help everyone, I think I can get the LCA's from the same place I got my rear disc conversion. Thanks again
dj theoretic
Oct 30, 2008 08:29 AM
agent marlon
Oct 13, 2002 05:07 PM
Blue-Civic-Hybrid
Jun 19, 2001 08:13 PM
