ECU help. info needed for future H-C accord
Old Dec 20, 2002 | 09:35 PM
smokin rubber's Avatar
Default ECU help. info needed for future H-C accord
Ok, For me to keep the accord in H3 or where ever class it is in when I start racing, I can not run a modded ECU or any other piggyback system ie VAFC.
So I need an ECU that will run my accord without blowing it up and without a speed governer. What are my options, it does not have to be and accord, or even USDM. But, it does have to be a OEM Honda ECU. Please help me roll all my competition.
Old Dec 20, 2002 | 10:03 PM
SlowLow5thGen's Avatar
Default Re: ECU help. info needed for future H-C accord (smokin rubber)
how would they know if you ran a chipped rom on your stock ecu? do the check your ecu software when you go for tech spec? if not just run a burned rom on the ecu, whichever suit's you best... if you can only use honda ecu's... maybe a p28
Old Dec 20, 2002 | 10:20 PM
KTeller8's Avatar
Default Re: ECU help. info needed for future H-C accord (SlowLow5thGen)
maybe a p28
Old Dec 21, 2002 | 12:35 AM
4doorH22's Avatar
I know the '92+ EX 5-speed ECU has no speed governor, but that probably won't work with your engine so well. Perhaps the '92+ LX 5-speed ECU has no speed governor? The P28 is SOHC VTEC and I'm not sure if it's a good match for your F22A2. I'm sure the H-C won't mind and ECU reprogrammed to remove speed governor, as long as the fuel/ignition/timing maps remain otherwise stock. No one should protest your ECU unless you start rolling H2/H1 cars.
Hey, looks like the DX/LX/EX all fall in H3... you could always buy my F22A6
Old Dec 21, 2002 | 07:28 AM
Default Re: ECU help. info needed for future H-C accord (4doorH22)
I IMed the honda challenge rules offical last night, and was told, "Not as currently written. Is there an alternate Honda (not reprogrammed) ECU that could be used? JDM or otherwise, that would be legal".
So I want to keep things legal. I will try and borrow somebodys p28 and do a back to back dyno pull, what year civics did they come in? Or if anybody has a 92 or 93 lx ECU that I could buy. I might try import auto salvage, or some local junk yard.
Dave I do want to buy your engine, but being out of work for 8 weeks sucks. I am moving up to Charlotte in the next couple weeks, and the money should be flowing again very soon.
Old Dec 21, 2002 | 08:16 AM
urbanlegend21's Avatar
New User
I do not believe P28 will work, this is a problem corey and I have been discussing with trying to build an 94 LX HC car
Corey and I are trying to go legal or get the rules changed a little bit to benefit Accords better
Glad to know that there will be some competitoin out there
Old Dec 21, 2002 | 11:41 AM
Default Re: ECU help. info needed for future H-C accord (urbanlegend21)
what is the problem with the 94lx, ECU?? I assume that you will be driving this accord, not Corey.
Old Dec 21, 2002 | 11:54 AM
New User
yeah I will be driving it, and maybe Corey will too
trying to get the most legal power out of the thing as possible, was looking at ECU's as a possibility, but I do not think we will go that route
hondanoob1
Aug 17, 2018 06:57 AM
TrademarkAccord
May 6, 2013 04:31 AM
acracer2008
Nov 7, 2010 07:51 PM
fmfkid250
May 7, 2004 06:09 PM
