Timing belt question??? need help
Old Dec 20, 2002 | 07:59 PM
smkngsr's Avatar
Default Timing belt question??? need help
Id like to know if theres a Balance Belt on the SOHC civic...its a 96 ex...
Is hard to replace a timing belt??? Is there anything that i should remember like tips to make it easier...appreciate the feedback
Old Dec 20, 2002 | 08:13 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Timing belt question??? need help (smkngsr)
Balance Belt?? Never heard of it.
It's really straight forward. Few tips which are pretty obvious..
1. Remove plugs-easier to rotate engine when finding TDC etc
2. replace water pump at same time-why not?
3. Torque tensioner to spec
Get a Helms/Haynes/Chiltons and you'll be fine. It's really straight forward. Just got to remove accessory belts, get engine to TDC and remove/replace. Instructions are easy to follow as well. Oh, get an OEM belt
Old Dec 20, 2002 | 08:17 PM
smkngsr's Avatar
Default Re: Timing belt question??? need help (Emerica)
Thanks bro...coz i did an accord before and theres a balance belt to smoothen the engine otherwise it will shake...and thats connected to oil pump...since u told me that theres no balance belt then, it should be easy then...thanks a million bro
Old Dec 20, 2002 | 09:09 PM
ricerocket2nv's Avatar
no civic has the balance shaft belt, and no its not hard to replace refere to a shop manual torque everthing to honda specs, dont want anything too loose, or too tight and could strip out bolts, don't attempt if you feel uncomfortable, one timing mark and then you will be in a world of ****.
Old Dec 20, 2002 | 10:15 PM
Evs-One's Avatar
Solbros Owns Me
Msciume53
Jul 5, 2016 01:00 PM
TheCrimsonGhost666
Oct 10, 2010 01:10 PM
honda2112
Apr 15, 2010 05:10 AM
Benhawk
Jan 29, 2007 11:49 AM
huge230
Oct 4, 2005 12:31 PM
