I CANT DECIDE prelude-turbo/ls turbo or Pvtec-turbo/Gsr turbo
Old Dec 20, 2002 | 06:37 PM
mugensport9's Avatar
Default I CANT DECIDE prelude-turbo/ls turbo or Pvtec-turbo/Gsr turbo
i cant decide what to get/build how does a prelude turbo compare to an ls turbo. how does vtec react to turbo's even with higher compression r they better for that sense a Pvtec-turbo/Gs-r turbo. i just want imput what do u think?
Old Dec 20, 2002 | 08:40 PM
sslude's Avatar
Default Re: I CANT DECIDE prelude-turbo/ls turbo or Pvtec-turbo/Gsr turbo (mugensport9)
you should build up the bottom end on a h23 nonvtec motor then turbo it. the compression isnt that high and it has more diplacement then a ls/vtec which is most likely a b18.
Old Dec 20, 2002 | 09:39 PM
laughinxxx's Avatar
New User
Default Re: I CANT DECIDE prelude-turbo/ls turbo or Pvtec-turbo/Gsr turbo (sslude)
If both motors are built and boosted, there is no replacement for displacement.
Edit: VTEC provides a small fuel tuning issue, but it is not a big deal.
[Modified by laughinxxx, 10:40 PM 12/20/2002]
Old Dec 21, 2002 | 12:47 PM
PrecisionH23a's Avatar
Default Re: I CANT DECIDE prelude-turbo/ls turbo or Pvtec-turbo/Gsr turbo (laughinxxx)
VTEC actually hinders performance on a forced induction motor due to the cam profile overlap. On the endyn superchargers they actually disable vtec. If you saw the article with the twin charged meguiars type r (turbo+s/c) you could actually see a small dip on the dyno chart when vtec was engaged. How big of a dip? In my opinion, its not that big of an issue unless you are a top drag racer and every little miniscule thing is critical.
Old Dec 21, 2002 | 02:45 PM
DSGB.'s Avatar
Dirty Bird
Default Re: I CANT DECIDE prelude-turbo/ls turbo or Pvtec-turbo/Gsr turbo (GudeH23a)
Why post almost the same exact topic in the same fourm?
chewymonster
10
Feb 14, 2007 08:10 AM
SupraRXZ
Dec 5, 2005 10:56 PM
blkteg15
Oct 10, 2005 07:39 PM
chasedatteg
Apr 17, 2005 06:33 PM
lowcivex
Feb 14, 2003 12:26 PM
