weight reduction ??!!
Old Dec 20, 2002 | 12:37 PM
4ghatch's Avatar
Default weight reduction ??!!
i just got my car weighed at a local gravel pit. I have a 91 hatch w/o all rear panels seats and pasenger seat. it was 2,050 lbs! i was suprized but that is without me in it and my goal is around 1,900 lbs. without driver so what car i remove to get that goal met? a/c,heat,anything else?
Old Dec 20, 2002 | 04:07 PM
EFsleeper's Avatar
Default Re: weight reduction ??!! (4ghatch)
AC will drop a considerable amount of wieght. It dropped like 115 lbs from my car. that should put you close to your weight. The compressor itself weighs a bunch, throw in the lines, the fan and the underdash stuff and you will be skinny like richard simmons...
Old Dec 20, 2002 | 04:39 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: weight reduction ??!! (EFsleeper)
i don't know what kind of AC system you had in it. but i weighted my parts after removal. 35lbs
of cource no coolant was present, but i doubt it is more than a few ounces.
my sunroof is next, followed by bumper support (replaced by custom, chrome moly ones)
stan
Old Dec 20, 2002 | 04:47 PM
travis's Avatar
Default Re: weight reduction ??!! (90crxsi)
stan
I don't know what the difference would be, but my AC system was 51 lbs. when I boxed it up and shipped it. Other easy ways to drop weight include the OEM exhaust, sunroof, and wheels.
Old Dec 20, 2002 | 05:09 PM
revman's Avatar
Default Re: weight reduction ??!! (travis)
Scrape off underbody coating, sound deadening material, and use lexan on non rolling windows. Wheels are a great weight savings, for every one pound off unsprung weight is equal to two pounds total, even greater the farther out you can get it (tires). Seats are an easy way to shed 50+lbs also.
Old Dec 20, 2002 | 06:55 PM
habib_88's Avatar
My AC was around 35 lbs too, that was just the underhood items (lines, compressor, coolant resivor, condensor). Figure also a header weights less than the stock cast manifold. If you replace your seats with aftermarket ones sometimes depending on the seat you buy you can loose a little there. Even replacing your stock steering wheel with a momo saves weight if you really wanna get down to little stuff haha.
Old Dec 20, 2002 | 07:17 PM
FourthGenHatch's Avatar
Default Re: weight reduction ??!! (habib_88)
I weighed my DX Hatch at a Landfill Weighing thing a couple months ago just without rear seats and no spare and it was 2,040 without me. But now I got rear discs, sway bars and other crap, I need to reweigh it but their scales aren't accurate all the time as each one will give a different reading.
Old Dec 20, 2002 | 07:19 PM
CHRIS 1.8's Avatar
Lose weight yourself. It helps.
Old Dec 20, 2002 | 08:10 PM
4ghatch's Avatar
Default Re: weight reduction ??!! (FourthGenHatch)
yeah, thats cool but what year is your hatch? I heard the 88 and 89 models are 200 lbs lighter then the 90-91's due to reinforced doors and other extras i'm not sure what they are but it's in another post
Old Dec 20, 2002 | 09:13 PM
SkylineGTR's Avatar
Obviously the A/C, heater. Get super light wheels. Gut the interior. Get aftermarket header/exhaust. Not only are they lighter but give better performance. I mean if you do all that you should be well below 2000 lbs.
Old Dec 20, 2002 | 09:30 PM
4ghatch's Avatar
Default Re: weight reduction ??!! (SkylineGTR)
thanks for all your help. I just have one last thing to ask. has anyone takin out there heating? how much did it weigh?
Old Dec 21, 2002 | 10:16 AM
SkylineGTR's Avatar
Actually the lightest CRX is the 88 HF. I think they are in at about 1890 lbs? It's somewhere around their and they are basically about 300lbs lighter than a 90-91 Si. That is something to consider if you really want a fast car. That is the best body to go with. I mean 300 lbs is a huge difference especially for light cars.
Old Dec 21, 2002 | 04:46 PM
Ben Ogle's Avatar
Mine is out. The heater itself weighs about 7-10 lbs. The control panel and linkage is probably another 2 lbs. Its not really worth it unless your car is not a daily driver (I wish I had mine still in and its not my daily).
Ben
Old Dec 21, 2002 | 05:59 PM
guttedEF's Avatar
Default Re: weight reduction ??!! (Ben Ogle)
I've got a '90 STD. All interior is gutted, tar removed, no heat or A/C. Has a CRX dash and console and still has door panels only. I've also got HX wheels and a stock B16.
I weighed it with only one '00 Integra leather seat and very little gas and it weighed 1930lb. without me in it.
Everything is removed, but nothing really cut out. I just removed the rear seat mounting brackets, and the jack holding bracket. I was kinda pissed about the weight with so much removed, but now it's time to start cutting.
[Modified by guttedEF, 7:00 PM 12/21/2002]
Old Dec 21, 2002 | 06:15 PM
Ben Ogle's Avatar
Default Re: weight reduction ??!! (guttedEF)
Mine (88DX 4 dr) is 2060 with a B18a, DA brakes all around, 90 teg wheels, 1/8 tank, and no tar, stereo, AC, spare, jack or heat. The rest of the interior is there, though (plastic, back seat etc).
Ben
Old Dec 21, 2002 | 11:28 PM
I Gotta Question's Avatar
The 87 weighs like 1500 lbs. Get one of those with a B series and hit some 13s in the 1/4.With weight reduction prolly 1200 lbs.
Old Dec 21, 2002 | 11:40 PM
robhamaliuk's Avatar
Default Re: weight reduction ??!! (89_CRX_HF)
Provided your car has power steering (Not sure that it does, my 89 dx does). I was told removing power steering removes about 50 pounds. But daily driving will be less appealing with this.
Old Dec 21, 2002 | 11:45 PM
Default Re: weight reduction ??!! (89dxer)
Actually you can barely tell you don't have it. Mine doesn't and it steers like no other.
Old Dec 21, 2002 | 11:48 PM
Maybe I should consider removing mine then.
Old Dec 22, 2002 | 12:42 AM
.Ryan's Avatar
Don't Trust Anyone
My CX with full interior/ac weighs 2094 lbs without me.
Old Dec 23, 2002 | 11:17 PM
SkylineGTR's Avatar
Default Re: weight reduction ??!! (SpoonSportsEH2)
NO, NO, NO,
A 87 CRX does not weigh around 1500 lbs. It weighs at the lowest, 1700 lbs. And to even suggest anything near 1200 lbs is simply ludicrious. Formula 1 race cars weigh about that much. Get the facts straight. I could be wrong but my educated guess is that a 87 CRX can weigh no less than 1700 lbs. Someone let me know if i'm wrong.
Old Dec 23, 2002 | 11:28 PM
martini's Avatar
my crx weighs 1980 with me in it (~230 lbs) and a full roll cage.
I wouldn't put much stock in your loval gravel pit scale, unless it's been recently certified. try a truck stop gas station, or call up your local department of licensing and find out where the local certified scales are at.
Old Dec 24, 2002 | 12:51 AM
Ham'ed Hatch
Guest
Posts: n/a
it's funny how this was never mentioned years ago (weight being an issue with rear disc conversions), but once ONE person says it, everybody uses it as an excuse.
Old Dec 28, 2002 | 09:34 AM
SIRX's Avatar
Default Re: weight reduction ??!! (mr. skelly)
I stripped mine and lost like 300 lbs very easily
post edited by breaka_1_9
Old Dec 28, 2002 | 12:24 PM
BudaKai's Avatar
Default Re: weight reduction ??!! (SIRX)
Umm my daily grind '87 hatch Si weighs 2134lbs. That's with turbo'd B16 though. Full interior and full gas. If you think '87's are ghey come race mine
