Need Coilover install help
Old Dec 20, 2002 | 12:00 PM
RicedREX's Avatar
Default Need Coilover install help
hey I bought some used coilovers and im gttin ready to put them on...I am just wondering if it matters where I put each spring, like if it was on the back of the old car can I put them on the front of mycar? and any tips on installing coilovers would be helpful, I have neer done it. [img]springs.jpg[/img]
[Modified by RicedREX, 9:02 PM 12/20/2002]
[Modified by RicedREX, 9:03 PM 12/20/2002]
Old Dec 20, 2002 | 12:26 PM
XwhitneyX's Avatar
Default Re: Need Coilover install help (RicedREX)
put the stiffer springs in the back, something I just learned outta this forum. And make sure you douse the bolts in penetrating oil and give 'em time to soak in.
Old Dec 20, 2002 | 12:58 PM
REDBARON's Avatar
Default Re: Need Coilover install help (XwhitneyX)
Actually you put the stiffer springs in the front. That's where most of the weight is. Other than that, it's basically just like installing lowering springs. The only thing your going to have to do is make sure all four corners are even. You will have to get a tape measure and adjust it to your desired height.
Old Dec 20, 2002 | 01:16 PM
E-AT_me's Avatar
Default Re: Need Coilover install help (REDBARON)
if you want your car to Push in corners.. if you swap it around, it will hook/oversteer.. which, for those who KNOW HOW TO DRIVE is good. for those who don't know how to drive, it's bad..
Old Dec 20, 2002 | 01:22 PM
REDBARON's Avatar
Default Re: Need Coilover install help (Rexman)
You're right about that. But normally the stiffer ones go in the front. Track cars or people that like to oversteer, have higher spring rates in the rear.
Old Dec 20, 2002 | 02:10 PM
RicedREX's Avatar
this is probably a dumb question, but the silver peice that allows me t ajust the height...does it just sit on top? what exactly do I with it...I know where it kinda goes and ****, but just for clarification, what exactly do I do with it?
Old Dec 20, 2002 | 03:46 PM
Tyson's Avatar
um, did you get these "coilovers" off of ebay? didt it not come with instructions???
the adjustable perch (the silver ring) replaces the lower spring perch. So you fit the threaded collar around the shock so it sits on the lower perch of the shock. any rubber rings you got is supposed to go around the shock tube so it gets sandwiched by the threaded collar and provides a snug fit.
Old Dec 20, 2002 | 04:55 PM
travis's Avatar
I'm a little worried about the fact that you're doing suspension work on your car and don't really know what you're doing. Not worth making your car unsafe. Post some pictures of your parts and we'll put the pieces together.
Old Dec 21, 2002 | 08:00 PM
joshwhe's Avatar
its not the best idea to put coilovers on stock struts they wont last very long
coilovers+stock struts =blown out ride
Old Dec 22, 2002 | 04:24 PM
Tee Jay's Avatar
Default Re: Need Coilover install help (joshwhe)
Don't forget about the WD-40.
You'll need that.
DJTazer
Suspension & Brakes
Aug 26, 2014 06:35 PM
silversleeper
Feb 28, 2007 12:23 PM
chizzadd
Oct 15, 2005 09:35 PM
pulse_crx
Jul 21, 2003 01:45 PM
samdawgsol
Feb 18, 2002 07:33 AM
