pressure plate removal???
Old Dec 20, 2002 | 10:20 AM
stRtypR25's Avatar
Default pressure plate removal???
got the tranny down . just to make sure, to get the pressure plate mounting bolts off you use an 11mm socket. you do not need a special socket or anything right?
Old Dec 20, 2002 | 10:27 AM
RTW DC2R's Avatar
Default Re: pressure plate removal??? (stRtypR25)
Not sure, but for workin on your car youself
Old Dec 20, 2002 | 10:28 AM
Dave-ROR's Avatar
I thought it was 12mm? eh whatever. you need a 12 point socket though.
Old Dec 20, 2002 | 10:30 AM
Willard's Avatar
6-10mm bolts
Old Dec 20, 2002 | 10:31 AM
Dave-ROR's Avatar
Default Re: pressure plate removal??? (Willard)
6-10mm bolts
you need 6-10mm bolts to remove it?
ok so it's 10mm, so you need a 10mm 12 point socket.
Old Dec 20, 2002 | 10:44 AM
stRtypR25's Avatar
Default Re: pressure plate removal??? (FyrStarter)
thanks for the help, i did not know that you needed a 12 point socket to remove the bolts
Old Dec 20, 2002 | 10:49 AM
Padawan's Avatar
Darth ModerVader
Me either - and somehow the CM flywheel and Exedy clutch found their way in anyway.
Yuta
Nov 9, 2015 09:41 AM
t-leclair
Transmission & Drivetrain
Oct 8, 2011 12:37 AM
Under Con. CrX
Feb 26, 2007 05:30 PM
Grnade
Jun 1, 2004 01:18 PM
