who has problem with wheel bearings?
Old Dec 20, 2002 | 09:20 AM
Nuts's Avatar
Default who has problem with wheel bearings?
my R has 22K and it started to make some noise on the driver side front. Brought it back to dealer, and the front wheel bearings will need to be replace (under warranty), just wonder if anyone else have similar problem?
find this thread in searcrh. https://honda-tech.com/zerothread?id=155692
is there any way I can check and see if all wheel bearings are in good condiiton before I go to the track?
thanks,
CS
Old Dec 20, 2002 | 09:30 AM
Back in Black's Avatar
Rather OG
Default Re: who has problem with wheel bearings? (CS)
Yes, shake the wheels while the car is on the ground and see if there's any "free play".
Jason-
who has replaced his driver front once...
[Modified by Jason Franza, 1:31 PM 12/20/2002]
Old Dec 20, 2002 | 09:33 AM
Rather OG
Default Re: who has problem with wheel bearings? (Jason Franza)
Just to add, I think Willard had some pics/illustrations on the subject.
Old Dec 20, 2002 | 10:04 AM
D's Avatar
D
not all bad wheel bearings will show free play in the hub.
Old Dec 20, 2002 | 10:22 AM
GRM Scott's Avatar
25 Year Member
Default Re: who has problem with wheel bearings? (D)
my right front went about 700 miles ago, lots of play and some weird noises.
my left front went about 100 miles ago, no play at all but some crazy whack noises.
car has 34,000 miles.
They're a wear item (under warranty is nice too).
I have a feeling as R's get older this will be a common problem, like the pop-open glovebox
Old Dec 20, 2002 | 10:31 AM
Rather OG
Tr00, though that has been my experience so far.
Jason-
who'll probably have a wheel fall off sometime
Old Dec 20, 2002 | 10:40 AM
EK Spec R's Avatar
i've had to replace both side about six months ago. easiest way would be jack the car up, and spin your tire, if you hear any noise coming from the hub, it's your wheel bearing.
Old Dec 20, 2002 | 10:43 AM
D's Avatar
D
my experience thus far has been the exact opposite. I've been through a few more bearings btw...
D
Old Dec 20, 2002 | 10:46 AM
Dave-ROR's Avatar
Jason-
I tried that once.. 150mph with hand tight lugs owns.
Old Dec 20, 2002 | 11:24 AM
Nuts's Avatar
Default Re: who has problem with wheel bearings? (FyrStarter)
Jason-
boy, 150mph and a wheel fall off??
CS
Old Dec 22, 2002 | 06:57 PM
Dave-ROR's Avatar
Jason-
CS
nah, wheel didn't fall off, if it did, the car likely would have spun right into D's car.
alscrx
18
Jul 26, 2009 10:51 AM
techforay
Honda Civic (2001 - 2005)
Oct 26, 2008 08:16 AM
B18c1_turbo
Mar 14, 2008 10:43 AM
jizno
Nov 23, 2005 01:57 PM
GSxRated
Aug 3, 2002 08:44 AM
