Rubbing or clearance issues with 215/45/16 Falken Azenis?
Question: Will i have any clearance issues on my R with the following?
16in Wheels
Falken Azenis in 215/45/16
Mugen Lowdowns
thanx for your inputs
[Modified by BlueR, 1:18 PM 12/20/2002]
16in Wheels
Mugen Lowdowns
You might have problem w/ rubbing with softest setting during a hard turn, but will be fine at med-high shock settings.
i thought you guys were my funky bunch
sean & yoshi, thanx for the info
[Modified by BlueR, 1:54 PM 12/20/2002]
BlueR : I just put these tires on my 16x7 +50 RH CP-035's, and am running H&R sport springs (29502, I think), which may lower an ITR a little more than the Lowdowns, and have not yet encountered rubbing or clearance problems.
FWIW... these tires are also wider and taller than the Bridgestone RE-010's they replaced.
Amazingly, so far (less than 400 miles), it is a more comfortable ride, with better dry grip.
HTH.
HTH.
thanx for the info, any is appreciated since i've already taken the plunge
