What is the best brake setup
for intense braking on the track. Im getting sick for fade and im getting ready to upgrade my system. Currently i have front disc and rear drum i drive a 97 civic ex cpe. i am also on a 15" wheel so i cannot get a big brake upgrade i would prefer to stick with that size wheel. Any suggestions?
i did do a search, and i knew if i posted this i would get someone telling me that...BUT i wanted new information ie* if there are any new products....Like what brand stainless steel lines what brand rotors(slotted only or drilled) and pads...best fluid... if upgrading to a gsr caliper would benifit me...
[Modified by Hybridhonda561, 6:16 PM 12/20/2002]
You mention braking on a track?? If this is a lapping or wheel to wheel type situation, try some Hawk Blues and if you are running Blackhawk Farms, you may want to add brake ducts.
Quality brake fluid (Motul 600) and stainless steel braided lines (Goodrich is good and reasonably inexpensive) also help a great deal.
i upgraded my brake system and i am very impress w/ it's performance, and i autocross a lot ... i have brembo cross drilled/slotted rotors w/ axxis metal masters brake pads and super blue racing brake fluid ... all in all i spent around $350 ... all worthed
first get rear disc..and give fastbrakes.com a call!!!
The keys to adequate brakes on track:
1. Tires. They are the only thing touching the ground.
2. Fluid. Must not boil at high temp
3. Pads. Must hold up to high temps
SS lines, big brake kits, rear brake conversions are all nice, but it is EXTREMELY hard to out-engineer the guys that design modern cars.
BTW, when i say adequate above, I mean fade-resistant and safe. Good enough, and probably better than average, but not the absolute best (b/c none of us needs the absolute best).
Sounds like that will work very well. Is there any advantage with going with gsr calipers. I beleive the piston diameter is a little larger?
There are benefits and tradeoffs to larger brakes. Nothing that you can do will make your car stop any faster: only the tires will stop your car. The larger caliper piston of GSR brakes will increase the clamping force of the pad against the rotor, though the costs are increased compliance in the system (poor pedal feel) and improper ratios compared to the MC piston. Remember that your stock brakes are designed to work with your stock MC.
One thing that I was thinking about is that if you have crappy tires, then you want to avoid lockup at all cost. So having a powerful brake system that overwhelms the tires quickly is definitely not ideal (static friction is assumed to be greater than kinetic).
Brakes are all about balance. Too much power/enegy in one area exaggerates weaknesses in other areas.
For about the zillionth time, if you haven't built brake ducts, you haven't taken the single biggest step available. Braking is about energy exchange - turning the kinetic energy of the car into heat energy. If that heat energy isn't dissipated to the air, the system comes to a thermodynamic grinding halt.
Once I am done with this big, damn paper, moved and settled, I think my first new project should be a simple, bolt-in front duct kit to sell to people who beat the bejeebers out of their front brakes.
Kirk
Kirk
Jettplane
14
Mar 11, 2013 05:35 AM
TRE_
12
Aug 11, 2002 09:53 AM
citanest
18
Jul 6, 2001 01:41 PM
