How To: How to calculate offset difference and wheel fit.
Old Dec 20, 2002 | 08:25 AM
vtec.dc2's Avatar
Default How To: How to calculate offset difference and wheel fit.
O.k., you purchasing new wheels, know the specs but not sure exactly how much it will stick out or not.
offset - good explanation found here http://www.tirerack.com/wheels/tech/offset.htm
"The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel"
so.. lets use 2 wheels
1) stock wheels: 15x6 inch + 45 offset | 6inch = 152.4mm
152.4mm/2 - 45mm = 31.2mm = distance from hub mounting surface to outer end of the wheel
152.4mm - 31.2mm = 121.2mm = distance from hub mounting surface to inner end of the wheel
2) rota slipstreams: 15x6.5 inch + 40 offset | 6.5inch = 165.1mm
165.1mm/2 - 40mm = 42.55mm = distance from hub mounting surface to outer end of the wheel
165.1mm - 42.55mm = 122.55mm = distance from hub mounting surface to inner end of the wheel
next,
122.55mm - 121.2mm = 1.35mm = this is by how much rotas will extend in
42.55mm - 31.2mm = 11.35mm = this is by how much rotas will extend out
Drew17th
14
Sep 24, 2008 04:56 PM
Ponyboy
Apr 15, 2007 12:39 PM
torqueless
Jul 13, 2005 12:12 PM
gribbs
Jan 30, 2003 11:58 AM
vtec.dc2
Jan 5, 2003 02:52 PM
