95 GSR cluster in 93 hb???
Old Dec 20, 2002 | 08:24 AM
curiousgpnoy's Avatar
Default 95 GSR cluster in 93 hb???
has anyone done this before??? just wondering if its worth the time and how it would look...please post pix!!!
Old Dec 20, 2002 | 08:36 AM
b16b hatch's Avatar
Default Re: 95 GSR cluster in 93 hb??? (curiousgpnoy)
http://patriot.net/~merritt/gauge.html
Old Dec 20, 2002 | 09:10 AM
WykidEH's Avatar
Default Re: 95 GSR cluster in 93 hb??? (b16b hatch)
Here you go. . . . . .
Jeramy
Old Dec 20, 2002 | 12:17 PM
HondaCutter's Avatar
Default Re: 95 GSR cluster in 93 hb??? (WykidEH)
can show pictures of the where the dash meets the door panel?
Old Dec 20, 2002 | 12:31 PM
anyone got pix in a 93 civic hb???
Old Dec 20, 2002 | 12:33 PM
Spade's Avatar
That''s what those are above. They swapped the Integra dash.
Old Dec 20, 2002 | 02:33 PM
Default Re: 95 GSR cluster in 93 hb??? (Spade)
well i was hoping to see how it looks with the stock hb dash...or does it not fit??? i figured thats what it was cause it didnt look familiar to me...but if anyone tried it with the stock hb dash please post pix...thanx
Old Dec 20, 2002 | 04:54 PM
mztykal's Avatar
Default Re: 95 GSR cluster in 93 hb??? (burp)
How hard was it to get the Integra dash in the Civic? :D
EDIT: N/M, saw your ImageStation link. That's some cutting. 0_0
[Modified by mztykal, 1:57 AM 12/21/2002]
Old Dec 21, 2002 | 10:23 AM
WykidEH's Avatar
Default Re: 95 GSR cluster in 93 hb??? (mztykal)
It wasn't hard at all. I had to cut at three places and add three to four wires to make everything work on the dash. The only thing that doesn't work on my dash is the "low fuel" light. My heater vents and all work like it was in a GSR. It took me one day to do the swap. If you want more pic's of the swap, I can post more and if you want certain pic's, just ask and I can go out there and take them. Thanks. . . . .
Jeramy
Old Dec 21, 2002 | 01:01 PM
AmginE's Avatar
Jeramy
.. on the same note, *can* you get the low fuel light to work? ill swap if i can get that to work, i want one!
Old Dec 21, 2002 | 01:08 PM
Extent's Avatar
Default Re: 95 GSR cluster in 93 hb??? (AmginE)
afaik you have to have an integra fuel tank to have that working. There's a sensor that the civic dosent have that triggers the low fuel warning light.
Old Dec 21, 2002 | 02:51 PM
WykidEH's Avatar
Default Re: 95 GSR cluster in 93 hb??? (Extent)
That is correct. Right now, I'm getting a fuel tank from a GSR and installing it on my '93 Civic CX. Then it'll all work!
Jeramy
Old Dec 21, 2002 | 05:34 PM
ChiBoy's Avatar
Do you really have to install the whole tank? I thought you could swap the fuel pump housing and get the sensor.
Old Dec 21, 2002 | 06:53 PM
SPOON_BeIgHtEeNsEe's Avatar
Jeramy
hey in ur post u said that the only thing that is not working is the low fuel??? did u get the hazard, rear defroster, and the light dimmer switch for the integra too work (i used the civic)? did u use the civic or integra harness???
Old Dec 21, 2002 | 10:59 PM
WykidEH's Avatar
Default Re: 95 GSR cluster in 93 hb??? (SPOON_BeIgHtEeNsEe)
Jeramy
I used a '95 GSR dash harness.
Also, you can't just put the senser in. If you take the rear seat out of a ;94 uo Teg and look under the seat, on the pass. side. You'll see a panel that unbolts with two wires running out of it. That is the "low fuel" light sending unit.
Jeramy
Old Dec 22, 2002 | 12:18 AM
JDMRob's Avatar
Hey this guy shows u a pretty damn good way how to do the installation.
http://students.washington.edu/krist...dm/lfi/LFI.htm
[Modified by JDMRob, 9:20 AM 12/22/2002]
Old Dec 22, 2002 | 02:16 AM
GSRrR's Avatar
Default Re: 95 GSR cluster in 93 hb??? (JDMRob)
Anyone has a write-up/how-to on putting the dash in? My brother and I might try this and want to know what we are getting ourselves into. TIA
Old Dec 22, 2002 | 10:58 AM
WykidEH's Avatar
Default Re: 95 GSR cluster in 93 hb??? (GSRrR)
Ok, give me your e-mail add. and I can send you how to do it and give you pic's also. It's npot at all.
Jeramy
Old Dec 23, 2002 | 08:56 AM
yaya's Avatar
this question is posted like every other week
yes it fits , no it doesn't fit perfect
you need the integ plugs to go with the cluster
you might even need to cut/ trim the civic dash
Old Dec 24, 2002 | 09:55 AM
HybridHatchC1's Avatar
Default Re: 95 GSR cluster in 93 hb??? (yaya)
hey jaermy did you use the stock civic door panels?
Old Dec 24, 2002 | 05:43 PM
WykidEH's Avatar
Default Re: 95 GSR cluster in 93 hb??? (HybridHatchC1)
Yes I did.
Jeramy
Old Dec 24, 2002 | 06:16 PM
PBTemplar's Avatar
Jeremy, where did you get the entire integra console / dash...Also how much?
TIA - Brian
Old Dec 24, 2002 | 06:19 PM
CoolKat's Avatar
Default Re: 95 GSR cluster in 93 hb??? (PBTemplar)
in the classifiels some members are selling integra dashed for 100 shipped. if you want it try to hope on it asap cause when i bought my teg dah for my civic i got it for like 200 and a 100 bucks for the dash is pretty nice.
hers one link for ya
https://honda-tech.com/zerothread?id=367057
Old Dec 24, 2002 | 06:24 PM
976's Avatar
976
New User
Default Re: 95 GSR cluster in 93 hb??? (CoolKat)
What cluster could I use that DOESN'T require cutting or much moddification. I get over zealous and ruin **** when I get a blade.
dopamean
Nov 19, 2008 07:00 PM
g_rant2006
Apr 21, 2006 03:07 PM
ted
May 26, 2005 01:38 PM
workman92
Oct 10, 2004 11:42 AM
_Keith_
Nov 11, 2003 05:57 PM
