question for you ppl w/ 440cc saturated injectors w/ VAFC hack
Old Dec 20, 2002 | 06:26 AM
lsvtec101's Avatar
Default question for you ppl w/ 440cc saturated injectors w/ VAFC hack
I got the walboro 255HP and VAFC.. now the injectors, i plan on running the vafc hack on a obd2 ecu. can i get away with saturated injectors so i dont have to use a resistor box or will the hack not work? thanks
Old Dec 20, 2002 | 06:43 AM
VTC_CiViC's Avatar
Default Re: question for you ppl w/ 440cc saturated injectors w/ VAFC hack (aemcivic_02917)
That's what I used, worked fine for me.
Old Dec 20, 2002 | 07:36 AM
cock head's Avatar
Default Re: question for you ppl w/ 440cc saturated injectors w/ VAFC hack (VTC_boost-less_CiViC)
you dont have to use the resistor box, for peak and hold injectors. you can go ot radio shack and get 10 oms 10watt resistors and connect them to your ground (most likely yellow with a black line). But saturated willalso work with out any madifactions to the wires.
cxVtecC1
Oct 8, 2004 09:08 PM
B18c1turboedEK
Dec 2, 2003 07:40 PM
Big Josh
Apr 2, 2003 09:50 AM
aemciv
Feb 26, 2003 11:31 AM
superduperman
Jan 29, 2003 09:39 PM
