How to calculate offset difference and wheel fit..
Old Dec 19, 2002 | 10:51 PM
vtec.dc2's Avatar
Default How to calculate offset difference and wheel fit..
O.k., you purchasing new wheels, know the specs but not sure exactly how much it will stick out or not.
offset - good explanation found here http://www.tirerack.com/wheels/tech/offset.htm
"The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel"
so.. lets use 2 wheels
1) stock enkei: 15x6 inch + 50 offset | 6inch = 152.4mm
152.4mm/2 - 50mm = 26.2mm = distance from hub mounting surface to outer end of the wheel
152.4mm - 26.2mm = 126.2mm = distance from hub mounting surface to inner end of the wheel
2) rota slipstreams: 15x6.5 inch + 40 offset | 6.5inch = 165.1mm
165.1mm/2 - 40mm = 42.55mm = distance from hub mounting surface to outer end of the wheel
165.1mm - 42.55mm = 122.55mm = distance from hub mounting surface to inner end of the wheel
next,
122.55mm - 126.2mm = - 3.65mm = in this case, stock will extend by 3.65mm on the inside.
42.55mm - 26.2mm = 16.35mm = this is by how much rotas will extend out
Old Dec 19, 2002 | 10:59 PM
DC2ITR's Avatar
Default Re: How to calculate offset difference and wheel fit.. (vtec.dc2)
Old Dec 19, 2002 | 11:06 PM
ITRbroham's Avatar
shit post warrior
Default Re: How to calculate offset difference and wheel fit.. (DC2ITR)
Who says the ITR forum is going down? Great post
Old Dec 20, 2002 | 07:41 AM
vtec.dc2's Avatar
ttt for daytime
Old Jan 5, 2003 | 08:56 AM
Dr Pooface's Avatar
I found this calculator that does the work for you: http://toy4two.home.mindspring.com/offset.html
Old Jan 5, 2003 | 02:27 PM
vtec.dc2's Avatar
Default Re: How to calculate offset difference and wheel fit.. (Dr Pooface)
mine gives more details, but good link , if i found that, wouldn't had to do all that writing..
Old Jan 5, 2003 | 02:52 PM
Tommy_Gunns's Avatar
I was just going to write something similar.
Good write up
-Tommy who is still looking forward to owning a set of 15x7's
Ponyboy
Apr 15, 2007 12:39 PM
torqueless
Jul 13, 2005 12:12 PM
Alexander
Mar 25, 2005 02:40 PM
gribbs
Jan 30, 2003 11:58 AM
