type r cams in b16a, does it require ecu swap for max efficiency?
Old Dec 19, 2002 | 07:15 PM
hughesl's Avatar
Default type r cams in b16a, does it require ecu swap for max efficiency?
I am planning to drop Integra type r cams into a b16a, my question this: to get the most out of this setup should I also swap the ecu. Will the Type r ecu work, or is it necessary to go with an aftermarket programable ecu, or can you just run the stock ecu, and have it account for the additional fuel/air/timing requirements.
Thanks for the info
Old Dec 19, 2002 | 07:28 PM
EFing8's Avatar
Default Re: type r cams in b16a, does it require ecu swap for max efficiency? (hughesl)
you can't use a type r ecu. get some adjustable cam gears and even a v-afc and you are rockin
Old Dec 19, 2002 | 09:50 PM
bryant's Avatar
Default Re: type r cams in b16a, does it require ecu swap for max efficiency? (CND_CRX)
cam gears tunning is all you really need, but more fuel and air woud be great.
Old Dec 20, 2002 | 12:36 AM
rice_classic's Avatar
Default Re: type r cams in b16a, does it require ecu swap for max efficiency? (CR-X)
I have 2 ecus... A stock one and a chipped one... The stock on is a pr3 and the chipped on is the pw0.. I had it chipped by Locash racing because they tested the program on a b16 with boltons and ctr/itr cams/valvetrain and said it produced the "most power". vtec at 5200 fuel cut at 9k. I use it when I autocross/hpde
if you get cams and do some adjusting then you NEED to go to a dyno and I recommend a vafc.
My car felt much faster after I put in the ITR valvetrain and I have stock cam gears set at stock settings.
Old Dec 20, 2002 | 05:48 PM
hughesl's Avatar
Default Re: type r cams in b16a, does it require ecu swap for max efficiency? (rice_classic)
Thanks for the info. Now all I have to do is round everything up, with the least amount of payroll expense.
91EF919
Jan 25, 2011 02:20 PM
HFP-EP3
Dec 2, 2007 03:05 PM
IGotVTECyo
Jun 24, 2005 03:44 AM
FRESH
Jan 30, 2003 02:37 PM
