replaced whole distributor now it bogs..
i had dizzy problems so i replaced it with a new (used) one..
now my car bogs in low rpms..did i get a fucked up distributor or is it just my timing? should i replace cap and rotor? plug wires..they seem fine to me..my car just bogs now..any input?
adjust your timing to spec (if it's retarded to hell, aside from harming your engine, it should run like crap --- car shouldn't bog if it's advanced). replace the cap/rotor ($15-$25), might as well to eliminate the possibility of them being bad. also, check your ECU for codes (dist. codes likely), could be a bad dist. you bought. check your spark plugs as well, make sure they're clean (should be a light tan color ~~~> good combustion, white is lean, black is rich).
rhdjdmda6
Jul 13, 2006 04:52 AM
ice11honda
May 14, 2005 05:47 AM
