Question about V-afc hack.....
Well, there would really be no point in the Hack if you just had the injectors and vafc. How do you plan to supply a proper amount of fuel to compensate for boost?
Get the Walbro 255 or 255 hp pump. The install takes less than 20 minutes and you can get a good deal on a pump from lightning on H-T.
If you plan to get the pump a little later, just limit your boost to 3-5psi and you should be fine.
[Modified by maxim, 5:35 PM 12/19/2002]
