Need help with injectors
Old Dec 19, 2002 | 09:04 AM
INTEGRAMIKE's Avatar
Default Need help with injectors
I have a 90 crx si w/ 88 si motor trannny and harness that I have been prepping for scca ITA class the past year. I have been trying to start it but i'm not getting fuel. I think the fuel injectors are not getting the signal to work. What sensors may be affecting this and why? Thanks for any help!
Old Dec 19, 2002 | 09:55 AM
Hello Bart's Avatar
Default Re: Need help with injectors (INTEGRAMIKE)
Make sure your injector grounds are bolted down w/ clean connections and also you can crack the line on the fuel rail a little and turn you car to the on position to see if you are actually getting pressure.I you do not you have a fuel pump problem.I am not sure if any sensors would tell the injectors not to pulse. most likely if it ran before then you did not hook up something correct,just a thought if you do have pressure try to adjust your distributor while you are cranking it.let me know what happens.
Old Dec 19, 2002 | 11:00 AM
Perfectionist's Avatar
If you're sure it's not getting fuel...
Listen for the fuel pump running for about 2 seconds when the ignition is first turned on.
Check fuse #37.
Check the main relay.
Check for power at the injectors. (the ECU grounds the injectors to pulse them)
And, obviously, check all the wiring related to the injectors.
Default Re: Need help with injectors (turbohatch13.0)
i have pressure to the fuel rail, my eye stinging told me that it was fuel that came out. also i just replaced the pump and tank and the pump can be heard working. so it must be between the fuel rail and the injectors. tonight i will un hook the return line and see if fuel shoots out.
rlembitz
Dec 24, 2010 09:04 AM
slamedcivic
Nov 2, 2006 02:49 PM
90civSi
Jun 22, 2006 12:23 PM
Sinner
Jun 6, 2003 02:25 PM
EGHatchy
Jul 14, 2002 11:25 AM
