Re: Chirping sound
Old Dec 19, 2002 | 07:21 AM
B18Redline's Avatar
Default Re: Chirping sound
Hello,
Whenever I shift gears whether it be from 1st to 2nd or 2nd to 3rd or even from 3rd down to 2nd I hear a chirping sound that is approximately a second long.
The sound only occurs when I push down on the gas pedal as I am letting off the clutch when either upshifting or downshifting. So basically this chirping sound only occurs when I push down on the gas pedal.
It's probably something loose, but I wonder what it is. Thanks for any advice on what it may be.
Old Dec 19, 2002 | 12:46 PM
ViZ's Avatar
ViZ
Default Re: Chirping sound (Redline07)
unless you cracking a joke about chirping your tires then its your belts they are worn and need replaced
[Modified by ViZ, 1:47 PM 12/19/2002]
Old Dec 19, 2002 | 01:40 PM
vimsen's Avatar
Check accesory belt tension before replacing belts.
Old Dec 19, 2002 | 05:08 PM
hondamanwill's Avatar
? shifter hitting heat shield
Old Dec 19, 2002 | 05:12 PM
94TealGSR's Avatar
Yeah, almost definatley a belt. Feel them, see if they feel tight... when mine are tight there's probably about 2mm of play? Anything more and they're probably loose. See if they're cracked at all... they may need replacing. Failing that, I dunno.
Old Dec 19, 2002 | 05:42 PM
EL Vap133's Avatar
You don't got an ACT unsprung clutch do you?
Old Dec 19, 2002 | 07:46 PM
b18C1_liLkyLe's Avatar
you must be joking. possibly sounds like a really weak attempt at showing off. and if this isn.t a joke, then wow! the chirping sound is the small domestic bird that often gets stuck under your driver's seat and likes to chirp when your car lurches when you shift like ****. hope that helps.
Old Dec 19, 2002 | 09:07 PM
:jdmshmaydm:'s Avatar
Default Re: Chirping sound (b18C1_liLkyLe)
I thought this was going to be a thread about how to chirp your tires.
Old Dec 19, 2002 | 11:16 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
it's not a single thing you described.
its the belts. he's not joking.
caliEJ8
Jan 26, 2016 02:26 PM
sixtodc2
Aug 27, 2011 10:59 PM
JDM00SI
Feb 13, 2005 06:45 PM
ITR0952
Aug 30, 2004 07:40 PM
mgf163
Apr 22, 2003 08:12 AM
