B16A Rex what to do next?
Old May 2, 2001 | 06:54 AM
Brandon Chun's Avatar
Default B16A Rex what to do next?
I have a 90 CRX DX with a B16A motor swap, generic intake/exhaust, Suspension Techniques F/R Swaybar, Energy Suspension Master Set,
Tok. 5-way adjustable shocks, Eibach Sportlines, Slotted Rotors, I just recently purchased a CTR Intake Cam, but its not installed yet, I know I will need the valve springs, maybe the Titanium Retainers..Do I need to install these at the same time? Or can I install the Intake Cam and do the springs and retainers later on (when I have a little more cash)? What mod should I do after this?
Thanks in advance
Brandon
Old May 2, 2001 | 07:04 AM
DragII's Avatar
25 Year Member
Default Re: B16A Rex what to do next? (Brandon Chun)
you should be alright dropping the cam in now...but i would upgrade your valves/springs asap.
Old May 3, 2001 | 01:55 AM
raene's Avatar
*phew* With all the go-fast parts you've got, I'd be more worried about slowing down... I'd convert to rear discs first of all, and maybe do a big brake upgrade (plus wheels & tires) before worrying about going faster
Old May 3, 2001 | 07:43 AM
PrjR Rex's Avatar
New User
Personally I wouldnt before I had all the parts needed yea it wouldnt create to much wear but how many times a week do you have to break into the motor, Im currently building a b-16, with a t3 turbo. Im doing everything Im going tot before I put it in as far as internal and head work.
Old May 4, 2001 | 04:40 AM
Red Civic T's Avatar
New User
Default Re: B16A Rex what to do next? (PrjR Rex)
You should also get either CTR or ITR ex. cam, and install at the same time - it will cost you more to do it all bit by bit. Go with the valvespring and retainer upgrade.
I had Tom Fujita at http://www.portflow.com do my head and he suggested retainers to be installed as mine showed a little wear with promises of more wear to come
Old May 4, 2001 | 07:53 AM
FSTRex's Avatar
Default Re: B16A Rex what to do next? (Red Civic T)
Brake upgrade. Definitely!
Old May 4, 2001 | 09:26 AM
Jesse H's Avatar
Default Re: B16A Rex what to do next? (99Sleeper)
actually, stock springs and retainers are fine as long as you don't rev past 8K...but then, what's the point right?
Old May 4, 2001 | 01:56 PM
FSTRex's Avatar
Default Re: B16A Rex what to do next? (Jesse H)
Cam gears, pulleys, headers, cat-back exhaust. Just to name a few
Fallriverb16
Jun 18, 2015 04:06 PM
ej2civic
Dec 1, 2006 12:36 AM
1quickvr4
Jun 5, 2005 08:25 AM
dingusjt
Sep 18, 2004 05:54 PM
wagon-r
May 8, 2004 12:22 PM
