gauge cluster wiring question
i currently have a 94 si w/ 98 b18c1. when i did the swap everything was fine except my stock tach does not work. does anyone know the wire color for the stock tach and is it possible to tap this wire into the distributor like running an aftermarket tach (to bypass running through the transmission and sensors and what not.) any help is appreciated. P.S. i am running the integra obd-2 engine harness with the civic obd-1 cabin harness.
If you are talking about a external tach its under the hood near the fire wall on the drivers side it should be blue with a rubber plug around the end of it. As for behind the cluster I have no idea for the 92-95 Call your local Honda dealer ask for the service dept. and have them look in the helms manual and they can find it. Or if your friends have a Helms ask them.
[Modified by b16b hatch, 9:51 AM 12/19/2002]
thelucysong
Aug 31, 2003 07:21 AM
xXx Justin xXx
Jun 13, 2002 07:20 PM
