Gas needle is off, but by how much.
Old Dec 18, 2002 | 09:22 PM
RCautoworks's Avatar
Default Gas needle is off, but by how much.
Well today I noticed my gas needle went down alot more then I would suspect since I did not drive it alot. So I am almost on E , I deceide to put 10 bucks in, which is normal. So I am filling it up and it stops at like 7.90 cents, I'm like odd, I look and its over flowing. I'm like wtf, this can't be right, 7.90 cents only fills it up about 5 and a half gallons. So that means when my needle was almost on E, I still had about 5 gallons left. Did my flaot in my gas tank just bite the dust, if so can I just go by the trip meter so I don't have to drop my tank. Any tips ? . Thanks
Oh by the way, anyone find it odd that I was just talking about autometer gauges and how the oem gauges ain't so accurate lol. Weird.
[Modified by 90blackcrx, 6:23 AM 12/19/2002]
Old Dec 18, 2002 | 09:31 PM
Default Re: Gas needle is off, but by how much. (90blackcrx)
I forgot to add this, right now my car is filled up to the top. And its about this far
|| from the F, alittle closer actually. So is that how far I am off by, so when I was getting close to the E, I was not really, I still had like 1/4 of a tank left. So maybe now its back to normal and it just messed up before because I have not gas in about a week.Maybe I will let it get close to E again, and fill it up with 10 dollors again. And see what happens. I still want to know what you guys would do ?
[Modified by 90blackcrx, 6:33 AM 12/19/2002]
Old Dec 18, 2002 | 09:34 PM
shorti's Avatar
can't you get at your float from under your back seats?
Old Dec 18, 2002 | 09:40 PM
Default Re: Gas needle is off, but by how much. (shorti)
I am pretty sure I can, it is under the little compartment. If so how hard is it to replace ? Or is it even worth the hassle ? I mean is it gonna stop working altogether soon. If its alittle off I can deal with it. I mean right now its full and alomst on F, but will it act up and go down or up more then it should ?
By the way, can this be because of a dirty fuel filter, I don't think so but just woundering. Also how much would a new sending unit run me, and would it be smart for me to get one from a junkyard ?
Well I did another search on this board, turns out I found some more topics. Seems that the sending unit is the problem most times in this case. My question now is, if I replace the sending unit, how would I know this fixed my problem. Is there anyway to test the old unit ?
[Modified by 90blackcrx, 8:05 AM 12/19/2002]
Old Dec 18, 2002 | 11:43 PM
Urban Business
Guest
Posts: n/a
the fuel levle sender is easy to replace. under back seats. or if the guage is just off:
fill the tank completely, pop off needle reposition at F and snap back on.
Old Dec 19, 2002 | 11:15 AM
Default Re: Gas needle is off, but by how much. (TorteX)
I will see what happens in the next couple days
[Modified by 90blackcrx, 7:03 PM 12/21/2002]
Old Dec 21, 2002 | 10:04 AM
Update : Yesterday I was sitting in the gas station and I just watched my needle go down. I was not getting gas, my friend had to grab something there. My car was on alittle incline so maybe this is why it went down, it went down to 1/4 of a tank. So I pull my car out of my garage today, its been about 10 hours since I was at the gas station,and when I pull my car out, its on alittle decline.And I noticed my needle went back up to alittle more then half of a tank. Now I can see why it would go down a, and then up cause of the inclines, but when the needle went down it never came back up intill the next day and I think it was because I parked on a decline. My question is why did it take so long to go back to normal and why did it only go back to normal when I was on the decline ? I understand the needle moves when your on a hill but it usually sits back to normal after your off. So could it be my gauge maybe ?
Old Dec 21, 2002 | 11:30 AM
91SIvic's Avatar
that happend to me... i kinda did the opposite than TorteX said.
i just unplugged my fuel pump(letting the needle drop all the way to the bottom, and then moved the needle to the middle of the E. seemed to of worked.
Old Dec 21, 2002 | 06:52 PM
AbaZ's Avatar
I think we need another update, I am very concerned on this situation...
pxlds
13
Feb 9, 2014 07:45 AM
hannslebo
Jul 4, 2009 10:09 PM
Canadian_EF
14
Mar 28, 2009 07:00 AM
ej1 pilot
12
May 6, 2004 07:16 PM
RCautoworks
Dec 18, 2002 11:42 PM
