Anyone know why I can't put my car in gear?
Old Dec 18, 2002 | 07:37 PM
youngkow's Avatar
Default Anyone know why I can't put my car in gear?
I did search, and all of the problems are for when the car is running. I can't put my car in gear when the engine is off. I just did a swap, and it was fine, but now more than half the time, I can't put it 1st, 2nd, etc. Is the two legs where the shifter connects to the shift rod at a 90 degree angle? I checked mine and it looks more like 60 degrees. Anyone have a pic of the part where the shifter connects to the shift rod? Thanks!
Old Dec 18, 2002 | 07:46 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Anyone know why I can't put my car in gear? (youngkow)
adjust your clutch if you have cable....... thats prolly your problem
Old Dec 18, 2002 | 08:26 PM
youngkow's Avatar
Default Re: Anyone know why I can't put my car in gear? (TeamUntouchableRacing)
I have a hydro clutch, but still, shouldn't I be able to put my car in gear without pressing on the clutch (when the engine is off of course)? Could my tranny be messed up?
Old Dec 18, 2002 | 08:53 PM
ATS*Mark's Avatar
OG triple OG
do you have fluid in the tranny , is your shift linkage hooked up correctly , is it the correct linkage?
Old Dec 18, 2002 | 10:47 PM
LB CRX's Avatar
if i read this correctly, youre having problems putting it in gear when the engine is OFF? i wouldnt worry about it unless it did that while the car was running. your shift linkage is probably off, i had the same prob with my crx.
Old Dec 19, 2002 | 05:26 AM
youngkow's Avatar
Default Re: Anyone know why I can't put my car in gear? (LB CRX)
So what was the remedy? Did you just buy a new shifter assembly? Thanks.
Old Dec 19, 2002 | 09:02 AM
youngkow's Avatar
1990_integra_DA9
Transmission & Drivetrain
Apr 20, 2009 03:57 PM
blue89hatch
Nov 19, 2008 09:00 AM
civic92si
Mar 31, 2007 08:34 AM
ragnaroek
Sep 16, 2004 08:53 PM
youngkow
Dec 19, 2002 05:32 AM
