need help with alarm wiring locations for 95 integra gsr
Old May 1, 2001 | 11:46 PM
BoroDB8's Avatar
From: Waipahu, HI and Irvine, CA, best of both worlds, USA
Default need help with alarm wiring locations for 95 integra gsr
Hi guys. can you help me out with the colors and locations of the wires i need for my alarm install? thanks
Old May 2, 2001 | 08:34 AM
SuperSteve's Avatar
New User
25 Year Member
Default Re: need help with alarm wiring locations for 95 integra gsr (maxspeeds)
Here you go..
The ignition harness is wrapped in black insulation under the steering column.
The constant power is a thick WHITE wire in the ignition harness.
Ignition is a thick BLACK/YELLOW wire in the ignition harness.
The lock wire is in the driver kick panal and it is BLACK/WHITE.
The unlock is also in the driver kick panal and is BLACK/RED.
The parking lights is a RED/BLACK wire in a green plug above the fusebox.
THe door trigger is a light GREEN/RED is in the driver kick panal and looks like a 14 gauge wire but is mostly insulated.
Old May 2, 2001 | 11:02 AM
BoroDB8's Avatar
Default Re: need help with alarm wiring locations for 95 integra gsr (SuperSteve)
great! thanks supersteve. does anyone know of any other locations? Just to keep my options open.
Old May 3, 2001 | 12:36 PM
tinter's Avatar
do you know what gauage the stock speaker wires are for a 94 gsr?
Old May 3, 2001 | 10:31 PM
SuperSteve's Avatar
New User
25 Year Member
Default Re: need help with alarm wiring locations for 95 integra gsr (tinter)
To tell you the truth I have never noticed but I am pretty sure it is like 14 or something like that. It should be fine to run amplified highs through unless you are running more than 200 watts to each speaker(not likely)...
scottmog
Audio / Security / Video
Oct 22, 2008 11:14 AM
njandrewg
Mar 9, 2005 12:22 PM
importzx
Dec 8, 2004 08:17 PM
InTeGrA B18b1
Dec 30, 2003 03:36 PM
yoshi234
Feb 12, 2003 08:29 AM
