Ass-Heavy
I went out for some spirited driving today... and my car feels ***-heavy. Integra sedan. When I am braking it feels like the rear end might break loose and start coming around or something... it just doesn't feel like a neutral weight balance. Which is odd, because the weight is more up front in FF cars like ours isn't it?
And will adding a JDM ITR Rear Sway Bar to my car only increase this tendency?
Ben
Ben
Yes, the sway bar will make your *** end more likely to come around. The sway bar makes the rear more "stiff", but in turn makes it makes it easier for it to break.
[Modified by G2LSS, 8:51 PM 12/18/2002]
i noticed that is if your in a turn and you lift off the gas the *** end feels like it's going to come around try having more of a neutral gas pedal(on the gas)through the corner or maybe be on the gas more.it's a wierd feeling but once i got it down you can us that to your advantage, like if the car starts to push lift off the gas and the back will come around.
43MA
Aug 19, 2002 05:18 AM
