running wires from the engine bay to the cabin
it depends where in the cabin you want the wires run...
look along the firewall (from the engine bay) there are various black grommets/plugs that go from the engine bay to the cabin area... depending on where you want the wires run (from battery/passenger side, center, driver side, etc) there are black grommets and pre-drilled holes... make sure you retain the grommet so that the wire doesn't rub/touch the metal on the hole.. otherwise after time.. if the plastic insulation on the wire wears out.. not so fun things can happen
viking-101
17
Jul 4, 2011 05:04 PM
ef93si
Dec 20, 2003 02:43 PM
