ARP Head stud intall questions?
Old Dec 18, 2002 | 03:04 PM
Tofurky's Avatar
Default ARP Head stud intall questions?
I tried searching, but came up with a variety of answers.
When installing the studs, do I
use a stud installer?
hand tight?
or do i try the backwards nut underneath a nut, and torque it down like that?
thanks
-erik
Old Dec 18, 2002 | 03:21 PM
93LSivic's Avatar
Default Re: ARP Head stud intall questions? (Ruckus138)
Hand tighten studs into the block. Dont handtighten the nuts on
Old Dec 18, 2002 | 03:25 PM
Tofurky's Avatar
Default Re: ARP Head stud intall questions? (93LSivic)
haha. i was talking about into the block..
so just hand tightening will do it?
Old Dec 18, 2002 | 03:27 PM
gtcali's Avatar
Double nut them! Hand tight doesn't work well (even thought it says it in instructions).
Hand tight - all the studs were at different heights, even with the moly lub provided.
Double nut - put one nut on one flare side up, then another nut flare side down, and tighten them against each other. use a use a wrench to seat them down all the way. Not real tight, but so they are seated all the way down.
[Modified by gtcali, 12:40 AM 12/19/2002]
Old Dec 18, 2002 | 03:39 PM
InfamousRS's Avatar
Default Re: ARP Head stud intall questions? (gtcali)
sems to be working just fine in my car....
Old Dec 18, 2002 | 05:47 PM
paulzy's Avatar
Default Re: ARP Head stud intall questions? (InfamousRS)
I double nut them to 14ft lbs...then torqued the head down to 70ft lbs
black0hatch
Honda CR-V & Element
Aug 30, 2012 01:29 PM
kabaroo
10
May 21, 2005 10:41 AM
95GSRTT
Apr 30, 2005 05:57 PM
Flamenco-T
Nov 1, 2002 08:23 PM
