T4 tubo on a singlecam
t4 may be too big for 1.6 sohc, try t3/t4
http://www.zex.com/Community/Gallery/
well if i use a t3/t4 i would probably go with a turbonetics stage 5 t3 exhaust housing with a t series compressor side maybe 60-1 or 62-1. im looking for 380 to the wheels. i want it to be streetable. i dont want to run over 20 psi. maybe this is impossible with a d16a6. if it helps here is a list of mods. ported and polished and extruded honed d26a6 head. o ringed head. oversized valves with stainless steel valves springs and retainers. golden eagle sleeved block. srp 8.5:1 compression pistons with eagle rods. arp head studs etc... im gonna use a haltech. but i wanna konw wut size turbo i should use before i start putting together a turbo kit for the car. thanx for all the replies guys.
I'd go with the 60-1 compressor housing. The 62-1 would be waaaayy too big for that littlesingle slammer. If you use a straight T4 your going to see a lot rpm's before you hit boost, but your boost will hit harder and make more power. Good luck with that tranny they like to break.
