Car shakes on the freeway...help!
Old Dec 18, 2002 | 01:28 PM
rivvin's Avatar
New User
Default Car shakes on the freeway...help!
I'm havinng a problem with my car. In the freeway at about 80mph or so the cars shakes really bad. It's like a side to side motion. And, sloing down from high speeds makes the car shake also. I don't know what's the problem. Could it be the engine mounts or alignmaent? Also, does Honda cover those two under warranty? Thanks for any info.
Old Dec 18, 2002 | 01:49 PM
niedejb's Avatar
Default Re: Car shakes on the freeway...help! (onetym408)
Sounds like alignment. Dont think it would fall under warranty, could be wrong.
Old Dec 18, 2002 | 02:06 PM
iam7head's Avatar
Default Re: Car shakes on the freeway...help! (niedejb)
my steering wheel shakes like **** when i go over 80+mph too(my beater that is)
Old Dec 18, 2002 | 03:06 PM
paul9luap's Avatar
Default Re: Car shakes on the freeway...help! (iam7head)
either you need a 4 wheel balance, or you have a flat spot on one of your front tires that is causing a vibration. it can be caused by suddenly braking, locking up the fronts, and wearing down the tire, leaving a flat spot.
Old Dec 18, 2002 | 05:03 PM
Guru's Avatar
Default Re: Car shakes on the freeway...help! (paul9luap)
I dont think its any of those things, i think you need to check your cv and ball joints those usually cause the car to shake at those speeds. I had a 88 prelude that did the same....
Old Dec 18, 2002 | 07:21 PM
DeLiRiOu5's Avatar
Default Re: Car shakes on the freeway...help! (Guru)
why do u hate coupes?
Old Dec 18, 2002 | 07:24 PM
frankdatank's Avatar
if the steering wheel shakes only at higher speeds its probably the balancing, if it shakes at almost all speeds its probably a bent wheel or bad front end part(cv joints) if it vibrates when you brake it has to do with the brakes, probably a warped rotor. nothin to serious though. any tire shop will usually inspect all that stuff for free.
Old Dec 18, 2002 | 08:00 PM
ratherbewalking's Avatar
no honda have to diagnos it and only replace the defected parts.
your problem is bad shock obsorver or u need four wheel balance.
is that english?
id check for warped rotars (possibly), torn or worn bushings. and alignment as mentioned above.
Old Dec 19, 2002 | 08:58 AM
JDM_CD7's Avatar
Default Re: Car shakes on the freeway...help! (ratherbewalking)
Welll .... to solve the problem with the "80mph shaker" question:
I had the same thing happen to my coupe, but in my situation it was a bad CV joint and also the 2 front tires needed to be balanced.
But with that situation in hand it could be these posilbilties:
Bad CV Joints
Wheel Balancing
Wheel Alignment
Torn Bushings
or Bad Strut
Old Dec 20, 2002 | 04:45 AM
jweller's Avatar
Default Re: Car shakes on the freeway...help! (JDM_CB7)
You probably just need the tires balanced and or aligned. not covered under warranty
Old Dec 20, 2002 | 05:05 AM
flrdaccrd's Avatar
Default Re: Car shakes on the freeway...help! (jweller)
do u have aftermarket rims? or drop your car at all?
Old Dec 20, 2002 | 04:36 PM
rivvin's Avatar
New User
Default Re: Car shakes on the freeway...help! (flrdaccrd)
Okay thanks for any help. It was the tires. I bought it used and it had bad thread on them so the dealer replaced them for free.
d0ugch0i
Dec 8, 2007 09:18 PM
GSR-T-
Aug 5, 2003 09:31 AM
panda
Jun 28, 2003 11:25 AM
Mish
Dec 23, 2002 10:11 PM
