enlarged Throttle body power gains
Has anyone bored out their TB, installed with headers and good intake system and measured results? I was told boring it to 64mm can increase hp in the 4 to 6 range. I have a 94 GSR.
my friend installed a jg throttle body and skunk2 intake manifold and got 7-9 hp, but lost 2 hp of torque. this was on his n/a gsr with intake, exhaust, headers.
2 hp of torque.
on an NA car it will hurt your driveability and will put any increase in power way up at the very top of your power curve, on a boosted car your power increase will come on quicker
the reason for the loss of torque is while the system may be flowing more air the velocity will be less
I cant quote you HP/FTlb increases .. but if you have a HIGHLY modified NA car .. IE: oversized pistons...cams .. complete airflow and fuel delivery overhaul... the throttle body would be the bottle neck at that point and be worthy of the bore
id recommend your fuel tuning be done after the TB bore
Also remember to port match the TB to the IM to get the best gains.
EDIT: I have had awesome service from www.proflowdesign.com
[Modified by zilverz, 11:35 PM 12/18/2002]
xxvinxx43
18
Aug 10, 2011 10:31 PM
hondaracin24
Oct 8, 2010 08:39 PM
