Brake Dust Shields
My g/f's cuz took the front dust shields off of the front susp. on his hatch and swears the brakes bite better---i have the night free so i'm thinking of taking mine off--is it worth it?-i mean honda must have put em' there for a reason.
the dust sheilds are there for dust and to keep small objects out of your rotors. you get a little more cooling with the dust sheilds removed, but i don't think the braking power would be alot greater.
the sheild also prevents water from getting splashed onto the rotor...water on the rotor can cause your brakes to slip until they dry (hazardous)....and if your rotors are hot, and get splashed, they will warp instantly.
gotta add this:
because I actually communicated.
gotta add this:
can u explain why it's a
If you want people to take u seriously u will first have to communicate properly.
I am not even sure if I understand what you were asking.
I think breaka answered your question though.
i dont think this is true.. once you depress the pedal the pads will squeeze all the water out almost instantaniously(sp) disc brakes are not subject to water fade as older drum brake systems are
Surewin
Mar 16, 2005 11:32 AM
wizzards581
16
Sep 17, 2003 06:16 PM
EF_LSVtec
May 30, 2002 02:35 AM
