correct head bolt torqe
Old Dec 18, 2002 | 10:22 AM
civic9389's Avatar
Default correct head bolt torqe
Old Dec 18, 2002 | 12:11 PM
IN VTEC's Avatar
Default Re: correct head bolt torqe (civic9389)
OEM Honda head bolts or ARP/AEBS head studs? What kind of assembly lube? -30W or moly lube?
Old Dec 18, 2002 | 07:30 PM
ndustryalGSR's Avatar
For OEM, 60 lbs/ft
Don't forget the proper sequence, so the head seats correctly and doesn't warp.
Old Dec 18, 2002 | 07:50 PM
IN VTEC's Avatar
Default Re: correct head bolt torqe (ndustryalGSR)
Found my manual.
Apply 30W to the head bolt threads. Put them in finger tight.
Torque each, first to 22lb*ft in the following pattern.
9 5 1 3 7
8 4 2 610
Go back and final torque them to 60lb*ft in the same pattern.
I can't find the instructions for the ARP studs, so I'll have to post those later.
eddie7978
Engine Machining & Assembly
25
Feb 22, 2018 08:19 AM
esombra23
10
Mar 1, 2015 11:22 AM
EG_HEAD_H4L
Sep 29, 2009 01:52 PM
Mike95lude
Aug 27, 2007 07:39 PM
DA_JDM
May 15, 2007 02:29 PM
