Upgrading nonobd injector plugs for my EF
Old Dec 18, 2002 | 10:08 AM
EF_LSVtec's Avatar
Default Upgrading nonobd injector plugs for my EF
Any suggestions...this is my set up: LS block/GSR head/ITR internals/CTR cams/balanced crank/PP head/skunk2 intake/70mm TB...
Old Dec 18, 2002 | 10:32 AM
ViperRedCRX's Avatar
Default Re: Upgrading nonobd injector plugs for my EF (EF_LSVtec)
what exactly are you asking???
Old Dec 18, 2002 | 10:36 AM
EF_LSVtec's Avatar
Default Re: Upgrading nonobd injector plugs for my EF (CRX-T)
I want to upgrade to bigger injectors...how many cc's is advisable? And are they expensive and worth the money?
Old Dec 18, 2002 | 11:01 AM
pretty sure a stock ecu will not idle anything bigger than 310's
Old Dec 18, 2002 | 11:09 AM
zCivic's Avatar
Well DSM 450 are available from a GSX or I'm pretty sure DSM 350's are on the N/A eclipse/talons. Either way you may need a AFC. You can get 92-95 Prelude injectors which are around 240's. Heres a few suggestions. Dunno how well those work on a stock ECU.
Old Dec 18, 2002 | 11:12 AM
Default Re: Upgrading nonobd injector plugs for my EF (zCivic)
i think preludes are 275cc, and all other honda 4cyl's are 235cc
Old Dec 18, 2002 | 11:13 AM
EF_LSVtec's Avatar
for the reply...I'll try to research further.
Old Dec 18, 2002 | 11:21 AM
zCivic's Avatar
I might have been wrong its 240 for others and 280 are prelude V-tec sorry about that, bad day at the job
Old Dec 18, 2002 | 11:22 AM
lol...i think everyone understands
Old Dec 18, 2002 | 11:52 AM
Jeff C's Avatar
You could use the lude ones, but I am using obd1 GSR injectors on my built crvtec and they seem to be fine. I mean would your motor require any more fuel than an ITR motor?
Old Dec 18, 2002 | 11:57 AM
zCivic's Avatar
Default Re: Upgrading nonobd injector plugs for my EF (Jeff C)
but isn't GS-R injectors high impediance?? You can use them but remove injector resistor box. There still 240's pretty sure though and OBD0 are all low impediance injectors, he want plug and play correct?? No rewires
Old Dec 18, 2002 | 12:01 PM
jdmhondageek's Avatar
Injector Specifications
VEHICLE Injector Types Flow Rate
1988-91 Civic si/crx si Peak and hold 240cc
1992-95 Civic si/ex Saturated 240cc
1996-00 Civic Saturated 240cc
1990-91 Integra Peak and hold 240cc
1992-00 Integra ls/gsr/type R Saturated 240cc
1992-96 Prelude non-vtec Peak and hold 240cc
1992-96 Prelude VTEC Peak and hold 345cc
1997-up Prelude VTEC Saturated 280cc
1991-up Sentra se-r/200sx se-r Saturated 265cc
1991-up MR2 Turbo Peak and hold 440cc
1988-91 Supra Turbo Peak and hold 550cc
1993-up Supra non -Turbo Saturated 315cc
1993-up Supra Twin Turbo Peak and hold 550cc
2000-up Celica GT-S Saturated 310cc
1990-up Miata 1.6 liter Saturated 215cc
1993-up Miata 1.8 liter Saturated 240cc
1993-up RX-7 Twin Turbo Saturated 550cc/850cc
1990-96 300zx Twin Turbo Saturated 370cc
1991-up 3000GT VR-4 Peak and hold 350cc
1989-up Eclipse Turbo Peak and hold 450cc
Below are a list of RC's sizes and prices for 'Peak and Hold' and Saturated Injectors.
PEAK AND HOLD
155 cc / min $78.90
185 cc / min $78.90
195 cc / min $79.85
210 cc / min $78.90
220 cc / min $79.85
250 cc / min $78.90
270 cc / min $82.50
320 cc / min $86.45
370 cc / min $84.50
400 cc / min $84.50
450 cc / min $85.36
500 cc / min $89.42
550 cc / min $95.42
SATURATED
160cc / min $76.50
185 cc / min $78.85
200 cc / min $79.90
210 cc / min $79.90
225 cc / min $81.50
240 cc / min 81.50
270 cc / min $83.75
310 cc / min $85.65
370 cc / min $88.30
440 cc / min $89.75
500 cc / min $135.00
600 - 800 cc + / min $150.00
this should help you out
Old Dec 18, 2002 | 12:11 PM
Jeff C's Avatar
Yes, I was just saying that I am using stock GSR injectors (240cc)...thats all.
Old Dec 18, 2002 | 07:08 PM
EF_LSVtec's Avatar
Default Re: Upgrading nonobd injector plugs for my EF (Ayanami)
I was going to switch mine to Type R plugs...but didnt realize they're the same flow rate as my current ones (91 teg)...What does peak and hold mean as suppose to saturated?
Old Dec 18, 2002 | 07:39 PM
zCivic's Avatar
Yeah sorry bout the disappointment on the flow rates. Peak holds and saturated always get me skrewed up. I'm not positive what it means or does but I know it must have something to do with the OHMs loads meaning you have to run the injectors with a injector resistor box or with out. PLEASE correct me if wrong I really would like to know the difference.
luis84one
Jan 9, 2012 11:23 AM
boostedrexy
Feb 15, 2010 06:44 PM
daltond88
Feb 2, 2010 07:44 AM
Propulsion
Dec 17, 2003 08:40 AM
X arkangel x
Apr 17, 2003 12:00 PM
