turbo+stock ecu+vafc = max injector size?
as the title says. ive posted before and didnt get many replies and didnt find much in the search. so whats the max i can run with a vacf, stock ecu with boost (goal is around 9-12 but after i get pistons,rods, ect which isnt for awhile). also could i run higher cc injectors if i get a better fuel pump? tia
Zip https://honda-tech.com/zerouser?cmd=viewprofile&id=1445 produces a product that allows you to run larger injectors with the stock ecu(370's, 440's and larger, etc) he is an Electrical Engineer, pretty smart guy. He is calling the product an SMC, here is a link to his site http://userwww.sfsu.edu/~ecg/smc.htm
Hope that it works for you,
Austin
Austin
SMC sure has a good price and supports up to 450cc injectors.. but it seems like more of fmu, it only mentions controlling fuel, nothing else - http://userwww.sfsu.edu/~ecg/smcfaq.htm#seven - it doens't work with vafc neither..
[Modified by vtec.dc2, 1:00 PM 12/18/2002]
Andy-
different people will tell you different things. Ernie was running 370's with his stock ECU when he had his R... and i know someone else running 440's on the stock ECU, both were only using a VAFC and stock ECU.
The v-afc or smc should be able to do 440's - 550's.
here is info on the v-afc hack: http://www.thedropshop.tv/vafc.htm
here is info on the smc: https://honda-tech.com/zerothread?id=310021
EkTurboHatch
Dec 24, 2002 09:57 AM
