I'm back. Post your tires and tire pressures
Old Dec 18, 2002 | 06:29 AM
4doorH22's Avatar
Default I'm back. Post your tires and tire pressures
What's up y'all? I'm back from a 2-week vacation in the Philippines. ****, I'd move there if not for the traffic. I was hoping to get some parts there, but the Lude was never imported there so the H22 never came there. ATR? Forget it. There are only a handful of imported H22s, probably all in stock Preludes.
Anyways, I've set to settle on a good daily driving pressure for any of my tires. For summer I have 225/50-15 Potenza S03s (15x7 K1s) and winter I have 205/55-15 SP Sport 5000s (15x5.5 OE wheels). For the S03s I usually run 36 PSI front and rear. Anyways, post up your tire and pressure info please.
Old Dec 18, 2002 | 06:46 AM
urbanlegend21's Avatar
New User
Default Re: I'm back. Post your tires and tire pressures (4doorH22)
Khumo Supra's 195-60-15 34 psi winter
- too much track time and driving in summer to have a constant psi, but genrally around the same thing
Old Dec 18, 2002 | 06:55 AM
smokin rubber's Avatar
Default Re: I'm back. Post your tires and tire pressures (urbanlegend21)
225-40/16 ecsta 712 on 16X7 @37psi f/r. 225-45/15 ecsta V700 on 15X7 36f 38r
Old Dec 18, 2002 | 06:58 AM
KTeller8's Avatar
Default Re: I'm back. Post your tires and tire pressures (smokin rubber)
215-14's i stay at 38
Old Dec 18, 2002 | 07:31 AM
KGAccord's Avatar
Default Re: I'm back. Post your tires and tire pressures (KTeller8)
summer dunlop Sp5000s 205 55 15 34psi
winter dunlop graspic ds-1 205 55 15 33psi
Old Dec 18, 2002 | 07:45 AM
Kazmans94cord's Avatar
Default Re: I'm back. Post your tires and tire pressures (KGAccord)
since this is texas and we have one season..summer...all year long ill run about 35psi...but the tires i got with these CL wheels suck so im lookin for a new tires...no clue what im gonna get though.
Old Dec 18, 2002 | 09:10 AM
ArchAngel Sabastian's Avatar
New User
Default Re: I'm back. Post your tires and tire pressures (Kazmans94cord)
khumo
[Modified by ArchAngel Sabastian, 12:10 PM 12/18/2002]
Old Dec 18, 2002 | 10:05 AM
iam7head's Avatar
Default Re: I'm back. Post your tires and tire pressures (ArchAngel Sabastian)
Kumho 711 40-205-17
33psi+-1
Old Dec 18, 2002 | 10:06 AM
iam7head's Avatar
Default Re: I'm back. Post your tires and tire pressures (iam7head)
and yeah...i still have my Biatchstore stock tires
Old Dec 18, 2002 | 10:25 AM
briq4's Avatar
205/60 15 Dunlop Sport A2's I keep em at 32 PSI cold and they are quiet around turns and good in snow/rain.
P.S. anyone with the 205/60's have rubbing issues in the back?
[Modified by briq4, 2:27 PM 12/18/2002]
Old Dec 18, 2002 | 12:01 PM
4doorH22's Avatar
Default Re: I'm back. Post your tires and tire pressures (briq4)
On what wheel? The stock ones? If it's an aftermarket wheel, the wheel's offset might have something to do with the rubbing.
Old Dec 18, 2002 | 01:58 PM
CD8's Avatar
CD8
205-50-15 falken azenis 35psi at all 4 corners.
225-50-15 khumo victoracers 40psi on all 4.
205-45-15 nitto 555r drag radials 22psi (only front two)
Old Dec 18, 2002 | 03:26 PM
Pauldo's Avatar
Bridgestone Potenza RE950 could really care less for them, but i got all four for $55 so i'm not complaining.
Anywho they're 195-60-15 and i keep them at 34-36 psi
Next i'm looking at Yokohama AVS ES100 size 205-50-15 anyone hear anything about those?
Old Dec 18, 2002 | 04:32 PM
briq4's Avatar
Default Re: I'm back. Post your tires and tire pressures (CB7 Driver)
OH yeah duh they are OZ F1 Cup, I bought them from the tire rack but they don't have offset listed?
[Modified by briq4, 8:33 PM 12/18/2002]
[Modified by briq4, 8:34 PM 12/18/2002]
Old Dec 18, 2002 | 05:08 PM
but what size are they?
Old Dec 19, 2002 | 05:24 AM
4doorH22's Avatar
You're rubbing the inside of the rear wheel well with a 205/60-15?
I dunno anyone running that size on a 4th gen, but I don't think it would rub.
Usually too-wide a tire causes rubbing problems, but in addition to being wider, a 205/60 will have a slightly taller sidewall than a 195/60 (stock 4th gen EX size) and the larger radius might be causing the rubbing. That, or for some reason Tirerack sent you wheels with an abnormally large offset would be my guess.
Old Dec 19, 2002 | 08:34 AM
vtec94's Avatar
New User
215/45/17 kumho 711
currently running at 36psi
Old Dec 19, 2002 | 11:01 AM
Bantam's Avatar
2nd Coolest Person in DFW
Ive got a 4th gen with 17x7's in the front with 215/45/17 kuhmo ecsta supra tires
that i keep at about 40 psi and for "winter"(i live in texas) if i need to, ive got stock sized michelin pilots that are at 35psi
Old Dec 19, 2002 | 12:04 PM
m0t0rhead's Avatar
Default Re: I'm back. Post your tires and tire pressures (tharptroy)
Nitto NT-450 205x40x17 50 psi all year round
Florida
Old Dec 19, 2002 | 12:32 PM
jweller's Avatar
Default Re: I'm back. Post your tires and tire pressures (Escobar)
I'm running 205/60/15 dunlop SP Sport A2 40psi fr/rr but they have only been on hte car about 2 weeks and most of that has been snow and rain, so I'm still looking for a good pressure on them.
no rubbing, but these are on a 6th gen. the oem size is 195/65, so it's not exactly a fair compairison.
[Modified by jweller, 4:33 PM 12/19/2002]
Old Dec 19, 2002 | 08:59 PM
1genCL's Avatar
Default Re: I'm back. Post your tires and tire pressures (jweller)
dunlop sp sport a2's @ ~38 psi for autox.
for the strip i drop the fronts down to 20 and 40 in the back.
my nittos are 215/45/17's and run ~40 psi all the time.
Old Dec 20, 2002 | 12:46 AM
ChrisLe182's Avatar
Default Re: I'm back. Post your tires and tire pressures (1genCL)
I have Yokohama Parada Spec-2s, 215/40-17. I keep them around 36-38psi. They are mounted on OZ Superleggas, and I just lowered my car with Pro-Kit springs and AGX shocks.
Old Dec 20, 2002 | 09:43 AM
slo sohc's Avatar
Default Re: I'm back. Post your tires and tire pressures (ChrisLe182)
205/50-17 kuhmo 712.... 41 psi.. but i dont know why. This looks like a lot of random information but no real technical info.
???'s
is there a formula using load rating and vehicle weight for proper psi?
what psi for what conditions/driving style
Old Dec 23, 2002 | 12:14 AM
vtecandy's Avatar
bridgestone G2 205/55/15 front and rear. front: 32psi, back: 30 psi.
awesome handling
darnizzle8805
Mar 2, 2015 05:11 PM
Understeer
Apr 21, 2003 09:31 PM
Renegade
Apr 4, 2002 01:05 PM
01PYTypeR#1140
Mar 8, 2002 08:38 PM
95gsr
Feb 18, 2002 06:57 PM
