Toda C's vs. D's
Old Dec 17, 2002 | 11:16 PM
Jowee's Avatar
Default Toda C's vs. D's
Can anyone explain to me the main differences between these 2 cams? I know to have either one you must have a fully built engine with high compression pistons, headwork, etc. Which one is more beneficial to road racing or drag? Which one puts out more hp? How steady is the power curve on each one? Which one can be daily driven with and keep a steady idle? Or any other usefull info on these cams.
Toda Spec C 12.5 mm,duration - 255 @ 1mm 12.5 mm, duration - 255 @ 1mm
Toda Spec D
Valve Lift Duration
Intake Primary 11mm 250
Intake Secondary 11mm 250
Intake High (VTEC) 12.9mm 305
Exhaust Primary 11mm 250
Exhaust Secondary 11mm 250
Exhaust High (VTEC) 11.9mm 315
[Modified by ITR 98 1162, 8:16 AM 12/18/2002]
Old Dec 17, 2002 | 11:22 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Toda C's vs. D's (ITR 98 1162)
wow... i didn't even know there was a D
Old Dec 17, 2002 | 11:24 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Toda C's vs. D's (dLo GSR)
I believe Spec D was made specifically for drag...hence the D.
Old Dec 17, 2002 | 11:25 PM
SurferX's Avatar
For those specs, I don't think the duration was taken at 1mm valve lift.
Old Dec 17, 2002 | 11:26 PM
sgT's Avatar
sgT
Default Re: Toda C's vs. D's (SurferX)
you are correct. thats total duration
Old Dec 18, 2002 | 06:06 AM
GQ 05YellowEVO8's Avatar
Default Re: Toda C's vs. D's (sgT)
Steve, arent you going to go for these cams now?
Old Dec 18, 2002 | 06:40 AM
CHEETAH's Avatar
the D's kill the valvetrain and should really only be used for full race applications ... the spec C is more daily-driver friendly. Power difference between the two is significant, but one is a full race cam with a lot more lift ... constantly have to check spring pressure too.... hence not for the everyday guy.
Greg
Old Dec 18, 2002 | 07:08 AM
Suprdave's Avatar
Default Re: Toda C's vs. D's (CHEETAH)
I once saw a NHRA Pro-Stock Team at my local drag strip, and the main thing they did after every run was check valve spring pressure. They had this awesome little clip-on tool and measured it really quick using leverage. I always wondered if such a beast was out there for Hondas.
Suprdave
Old Dec 18, 2002 | 09:01 AM
cw98typer's Avatar
Default Re: Toda C's vs. D's (Suprdave)
Damn Toda D's, i was interested in A's. Crazy **** man........
Old Dec 18, 2002 | 09:31 AM
CHEETAH's Avatar
I use the Mac one ...
greg
Old Dec 18, 2002 | 10:12 AM
Suprdave's Avatar
Part #? Id like to get one...
Suprdave
Mashimaro
Dec 12, 2008 11:03 AM
hrs-parker
May 31, 2008 09:31 PM
chris2000
14
Nov 2, 2006 06:59 PM
Maxi
Sep 27, 2001 01:54 PM
