G2 wiring differences?
Old Dec 17, 2002 | 08:03 PM
made in JAPAN's Avatar
Default G2 wiring differences?
i am about to drop an already built ls/vtec motor in my 92 teg. the block and tranny are both from a 91. is any of the wiring that im going to have to deal with different????
Old Dec 17, 2002 | 08:13 PM
Padronis's Avatar
Default Re: G2 wiring differences? (made in JAPAN)
90-91 are non obd motors. 92-93 are obd1. How to actually wire it up right, I dunno, I'm sure someone else will graciously tell you. Try http://www.g2ic.com ? Just a thought.
Old Dec 17, 2002 | 08:24 PM
Default Re: G2 wiring differences? (G2LSS)
i know about the obd and obd1 differences...is there any onther differences, are the plugs the same?
Old Dec 17, 2002 | 08:27 PM
teg92's Avatar
Courtesy member dplatt,
http://www.g2ic.com/tegtips/engine/E...Swap_Guide.doc
http://www.g2ic.com/tegtips/engine/ECU_Pin_Outs.xls
Old Dec 18, 2002 | 07:13 PM
hondamanwill's Avatar
you'll have to change all the injectors and dist everything else should be the same
Old Dec 18, 2002 | 09:31 PM
Default Re: G2 wiring differences? (hondamanwill)
sweet...i hope thats all, i already have the distributor and injector problem solved
vietnamezerice
Jan 15, 2020 04:00 PM
91crxKhaos
Nov 29, 2017 08:57 PM
TwoKSiR
Oct 31, 2007 02:01 PM
1blownnteg
10
Aug 4, 2004 01:06 PM
89 JDM CRX
Mar 21, 2004 01:49 PM
